Did anyone else noticed that Prusa Core One camera doesn't work anymore ? When i try to reload my "generic camera" i get an "unresponsive" error. Camera definitely works, because i get picture in prusa app, IP address DIDN'T change (i have mac bind in router). When i removed generic camera now i can't add it anymore. It worked perfectly until now.
Also: changelog for 2026.6 Prusalink says:
3D printers gained more sensors: X/Y axis position, location, minimum extrusion temperature, plus SD ready, farm mode, and connection status binary sensors.
but i don't see any new sensors on my printer, not in my C1, not in MK4S. I did reload, restart HA...
First step is to restart HA ans make sure your integration is running the latest stuff not something cached.
After that check if there are open issues for the integration PrusaLink - Home Assistant
After that if you still have an issue, and there is not a matching issue in the issues, write an issue up and include all the data you can connect.
Restarted a few times, cleared cache. I didn't find any complaint here on this forum. I'll try on github. But i find it pretty odd that, as it seems, noone else complained (yet)... so i wonder, if it's me what else can i do...
EDIT: if i searched correctly there's no open things on core or frontend...
I found the problem for my camera: it seems that either camera FW upgraded, resetted or ... but somehow camera stream setting changed from RTSP to WebRTC camera (whatever that is...). I'm sure as hell that i didn't change that... Changing back to RTSP and picture is back.
But supposed "new sensors" mistery remains...
