The past weekend i migrated all the different eco systems i had to Home Assistant. Connected all the zigbee stuff to a zigbee USB stick on a raspberry pi with Home Assistant installed. For the most part it works great. There is just 1 thing really missing imho and that’s a PS5 integration. I found this
But it says in the addon that it’s no longer maintained. Had a lot more luck with the edge version. But i am a bit wary about how long it will keep working.
The issue is that switching ON the PS5 is registered fine. However when i switch it off it reports in the logbook as “unavailable” which isn’t a state i can attach to a device trigger. If the device trigger is “Powered off” the automation doesn’t work.
Maybe this can be resolved with a MQTT trigger? I have no idea how to get this working. Is this addon still being used by anyone and if so what is your solution for the “unavailable” state?
The feauture request is for a working supported official integration for the PS5 like there is for the PS4. Not to get support on the no longer maintained addon that may or may not work in 1-2 months. I was just pointing out that that is the only alternative for a official integration i could find and i don’t really see it as a proper alternative.
OK thanks for clarifying that. There’s still the request for a official integration for the PS5 like the one for PS4.
But i am sure that has requested before and there must be reasons this is not happening.
