PSA: Alexa Media Player v4.13.3 breaks all versions of Home Assistant
You seem to be on HACS 2.0 so in HA go to Developer Tools > Actions and then
action: update.install
  version: v4.13.2
  entity_id: update.alexa_media_player_update
then if you check the update.alexa_media_player_update entity it’ll show the installed version
I think I’m good right?
Reboot safe?
Goto Hacs press the 3 dots icon. Redownload and select the other release. Download and restart
Please can Home Assistant add a limit to prevent memory leaks or an addon using soo much RAM that it crashes.
I’ve found there is an option to limit RAM usage by add-on but it’s not implemented by default.
Yeah think so…if you have AMP Integration disabled it’ll not impact HA anyway…
Add-ons and Integrations are two different things…AMP is an Integration rather than an Add-on…
In your other thread where you mention Node Red that is an Add-on.
(but a good idea if it’s possible)
Thanks a lot! this was wrecking my head all evening trying to figure out what was happening!
SO glad there is a post about this! I upgraded to 10.0 and got the memory leak errors! Fortunately I had a full backup less than a month old.
If I disable the update entity in the Alexa Media Player integration, it’ll stop bugging me for updates (for now) correct?
I hope this finds a new stable home. I use this one a LOT!
Very grateful for this community today!
Thank you for this thread!
I’ve been pulling my hair out all day! :slight_smile:
Thank you for this. I had updated Core yesterday and then saw the update tonight for Alexa Media player. As soon as I updated AMP, I got stuck in the boot loop. When I started searching for an answer, this thread popped up.
Fortunately, I was able to trigger a restore in-between reboots to when I updated the core yesterday, and all seems okay after reinstalling the Core update.
This time when AMP notified me of the update, I skipped it.
Glad I found this… I still had AMP installed, even though it wasn’t in use. Uninstalled and all is good.
Of course, in the interim, I used this as an excuse to upgrade the HP 800 Mini G1 to a G5 version :smiley:
now 4.13.3 has been removed as an update will HA stop blocking it, I mean I never updated to 4.13.3 and yet I got failed to setup and removed and try to re add but authing is in a loop now (enter user, then password then back it goes to user lol)… I litrally use alex just for actionable notifications and thats it.
So… anyone got any idea on Alexa Media Player Alternatives?
I reinstalled AMP 4.13.2
Is now running stable since I rolled back
as FYI…looks like the plan to block AMP in HA has been reverted according to this PR now that AMP v4.13.3 has been pulled
@poudenes you asked about the block too so just FYI
DOH!
Wish I’d seen this first. In debugging I removed AMP and now trying to reinstall it I can’t get past the Amazon.co.uk login screen. 2FA is good and matches, grrrrr
“Solution” :laughing:
@Richi_Bowzer @chrisExh try this to solve the login screen issue.
All thanks go to @dbrunt who made a simple, step by step tutorial with pics!
I had a look through that and yes it does look like a lot of work. I mainly use my Amazon Echos as announcement speakers in HA and have some quite complex scripts to collate all the information I need for a particular announcement then send it to an Echo in whichever room I am in.
I couldn’t see any way of doing that from this skill. I might just switch to local voice once I get my local voice assist set up. It’s the one advantage Google speakers have over Amazon.
Amazon doesn’t seem to let you do that in routines. It’s also not designed to allow for dynamic content; it’s pretty much just for “fixed” stuff.
I can think of a kludge, but it’s a bit messy… have a virtual switch for each room/message you you would want, and have a different routine triggered from each switch. Then your complicated HA setup would decide which switch(es) need to be triggered. It doesn’t scale too well, but if you just have 5 rooms and 3 messages then 15 switches and 15 routines is managable…
Hi everyone. I’m glad I found this thread. I’m not exactly sure what to do, but I’m stuck where I can’t get into HA via a browser nor through SSH. I have a ping -t going, to see if it truly rebooting on me like the others, and if so I going to log in as quickly as possible and disable the Alexa.
Still, I’m not able to get in, what are my options? I have a back up from 3 days ago.
