Upstream supervisor has a closed “not planned” bug report titled Ingress blocking duplicate response header names #4290 which means addons with applications with multiple set-cookie headers for sessions and authentication are not supported.
I was able to workaround with a resolution. I relied on nginx to do the heavy lifting.
Backend to client: nginx receives multiple set-cookie response headers. nginx combines all of the cookies into a “super” or unified cookie. nginx sends one cookie to client (and discards backend cookies without sending them to client).
Client to backend: nginx receives “super” cookie. nginx breaks up cookie and sends multiple cookies to backend for session management success.
I have been developing a wireguard UI addon and it maintains session with multiple cookies. You may find more details and nginx source code at nginx can fix home assistant ingress with multiple set-cookie headers · Issue #5 · samrocketman/addons-homeassistant · GitHub
Side note: I would have commented in the original reported issue this workaround, but it is locked and I do not have access to comment. If an admin or moderator could comment on my behalf in the original issue that would be great! I spent almost a week in nginx and hassio docs as well as nginx and hassio source code before I came up with this solution. I didn’t ask for help in the forum to respect time of others.
I made 2 PRs that fixes this issue:
main ← RubenNL:addons-ingress-multiple-cookies
opened 01:31PM - 04 Jul 25 UTC
## Proposed change
The supervisor (and core) ingress only supported 1 hea… der with the same name. Applications frequently set multiple cookies in 1 response.
This change fixes the response, and also the request. I haven't found a situation where this matters, but it's possible in the HTTP spec.
## Type of change
- [ ] Dependency upgrade
- [x] Bugfix (non-breaking change which fixes an issue)
- [ ] New feature (which adds functionality to the supervisor)
- [ ] Breaking change (fix/feature causing existing functionality to break)
- [ ] Code quality improvements to existing code or addition of tests
## Additional information
- This PR fixes or closes issue: fixes #4290
- This PR is related to issue: https://github.com/home-assistant/core/pull/148148
- Link to documentation pull request:
- Link to cli pull request:
- Link to client library pull request:
## Checklist
- [x] The code change is tested and works locally.
- [x] Local tests pass. **Your PR cannot be merged unless tests pass**
- [x] There is no commented out code in this PR.
- [x] I have followed the [development checklist][dev-checklist]
- [x] The code has been formatted using Ruff (`ruff format supervisor tests`)
- [ ] Tests have been added to verify that the new code works.
If API endpoints or add-on configuration are added/changed:
- [ ] Documentation added/updated for [developers.home-assistant.io][docs-repository]
- [ ] [CLI][cli-repository] updated (if necessary)
- [ ] [Client library][client-library-repository] updated (if necessary)
[dev-checklist]: https://developers.home-assistant.io/docs/en/development_checklist.html
[docs-repository]: https://github.com/home-assistant/developers.home-assistant
[cli-repository]: https://github.com/home-assistant/cli
[client-library-repository]: https://github.com/home-assistant-libs/python-supervisor-client/
## Summary by CodeRabbit
* **Refactor**
* Improved handling of HTTP headers for more robust and consistent processing when accessing add-ons through ingress. No visible changes to user experience.
dev ← RubenNL:hassio-ingress-multiple-cookies
opened 01:37PM - 04 Jul 25 UTC
## Proposed change
The core (and supervisor) ingress only supported 1 heade… r with the same name. Applications frequently set multiple cookies in 1 response.
## Type of change
- [ ] New integration (thank you!)
- [ ] New feature (which adds functionality to an existing integration)
- [ ] Deprecation (breaking change to happen in the future)
- This PR is related to issue: https://github.com/home-assistant/supervisor/issues/4290 https://github.com/home-assistant/supervisor/pull/5996
- Link to developer documentation pull request:
- Link to frontend pull request:
## Checklist
- [x] I have followed the [perfect PR recommendations][perfect-pr]
- [x] The code has been formatted using Ruff (`ruff format homeassistant tests`)
If user exposed functionality or configuration variables are added/changed:
- [ ] Documentation added/updated for [www.home-assistant.io][docs-repository]
If the code communicates with devices, web services, or third-party tools:
- [ ] The [manifest file][manifest-docs] has all fields filled out correctly.
Updated and included derived files by running: `python3 -m script.hassfest`.
- [ ] New or updated dependencies have been added to `requirements_all.txt`.
Updated by running `python3 -m script.gen_requirements_all`.
- [ ] For the updated dependencies - a link to the changelog, or at minimum a diff between library versions is added to the PR description.
To help with the load of incoming pull requests:
- [ ] I have reviewed two other [open pull requests][prs] in this repository.
[prs]: https://github.com/home-assistant/core/pulls?q=is%3Aopen+is%3Apr+-author%3A%40me+-draft%3Atrue+-label%3Awaiting-for-upstream+sort%3Acreated-desc+review%3Anone+-status%3Afailure
[dev-checklist]: https://developers.home-assistant.io/docs/development_checklist/
[manifest-docs]: https://developers.home-assistant.io/docs/creating_integration_manifest/
[quality-scale]: https://developers.home-assistant.io/docs/integration_quality_scale_index/
[docs-repository]: https://github.com/home-assistant/home-assistant.io
[perfect-pr]: https://developers.home-assistant.io/docs/review-process/#creating-the-perfect-pr
After those 2 are merged and a new release is created, the workaround would no longer be needed.
Nice it took a high level of effort on my part to figure out the workaround.
I found an old HA issue where the developers stated they wouldn’t support the use case so I didn’t consider contributing code because of that old issue.
Hopefully, it is addressed.
