PSA: Improve ESPHome FPS with Clock Rate (why?)
Hey everyone :wave: I’ve been reading posts for a few weeks now and I recently decided to finally sign in, so I could briefly share my experience setting up an ESP32 cam and see if anyone here knows why this happens.
I had bought a Cam S3 dev board and an OV3660 from AliExpress just to tinker around with and I started with what was pretty much a default ESPHome Camera config. I was disappointed with the frame rate (I could get 0.4fps or so on a good day)… right away, but I assumed it was just a cheap board thing . Then I did some more looking into ESPs, and I realized the S3 N16R8 with 8MB of PSRAM is actually pretty powerful.
So I started experimenting. I first changed the WiFi power. That helped, but it also made the ESP reconnect to the API every minute. Then I tried changing the resolution, and that helped (brought sizes down considerably in logs) but for some reason I still could not get it displaying well.
So I was about to give up and attribute it to ESPHome bloat or ESP32 lack of hardware encoding, when I suddenly remembered a single comment on Reddit about the clock rate. I tried 10MHz which was as low as ESPHome says it can go. This improved things by maybe 20%. I lived with that for a while and I remembered that the comment mentioned 8MHz, so I decided just to try inputting it. It worked!
I was expecting little to no difference, but the MJPEG camera stream is now pretty much 3-4fps and it’s 2 or so FPS through the API, and this is at JPEG 15 at 1600x1200.
So PSA - if you have a pretty fast ESP board but are getting slow camera performance, try changing the clock rate. It makes a massive difference, and at least for the OV3660, you need a low clock.
I looked online and even tried asking AI, and I can’t really understand / find a definitive answer about how exactly the clock rate could change it this much? Can anyone explain it to me?
Also, there is one major trade off/bug. Before, when I tapped the live feed in Home Assistant, my on_stream_start/stop automation to work the LED worked perfectly. Now, if I use Home Assistant to view the feed, it constantly triggers on and off. For my logs, configuration, and more details, check here on my GitHub issue.
Any ideas?
Freaking legend!!! Had so many problems with this camera (esp32 not s3) and 16MHz is night and day… Went from 1 frame per 10s to 6.5 per second at 640x480.
Phenomenal! I’m glad this post helped someone out :slight_smile:
