Greetings,
I integrate an onvif camera to home assistant without problems and my camera has PTZ, but for any reason that I still can’t figure it out when i call the service onvif.ptz to move my camera it always get the same error:
2021-08-19 13:41:56 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [547277151728] 'NoneType' object has no attribute 'relative'
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 185, in handle_call_service
await hass.services.async_call(
File "/usr/src/homeassistant/homeassistant/core.py", line 1491, in async_call
task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1526, in _execute_service
await handler.job.target(service_call)
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 665, in handle_service
await service.entity_service_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 658, in entity_service_call
future.result() # pop exception if have
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 856, in async_request_call
await coro
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 695, in _handle_entity_call
await result
File "/usr/src/homeassistant/homeassistant/components/onvif/camera.py", line 196, in async_perform_ptz
await self.device.async_perform_ptz(
File "/usr/src/homeassistant/homeassistant/components/onvif/device.py", line 389, in async_perform_ptz
if not profile.ptz.relative:
AttributeError: 'NoneType' object has no attribute 'relative'
the user that i’m using for onvif has permission to use ptz so i don’t really know what else to do.
Please any advice will be appreciate it.
