Public charging apis?
Hi there,
I own an electric vehicle and have to charge it every now and then on the streets.
There are several public chargers around and loads of apps to show them (Chargemap, A Better Route Planner, Airlectric and so on).
All those apps show the public charging points as well as if they are currently used or open. I don’t know what API those apps are using.
But I would love to see this data in home assistant, for example to trigger an alarm whenever the charing point around my house gets free.
https://openchargemap.org/site/develop/api#/operations/get-poi
could be a start point
Bit misleading the title. I thought it was about killer bees. :frowning_face:
Have you solved this? Does HA have an integration for openchargemap already? Thanks.
I solved it somehow. I am using the map from ENBW Ladestationen finden and use the REST integration.
rest:
  - scan_interval: 60
    resource: https://enbw-emp.azure-api.net/emobility-public-api/api/v1/chargestations/xxxxxxxx
    headers:
      Host: 'enbw-emp.azure-api.net'
      Ocp-Apim-Subscription-Key: 'yyyyyyyyyy'
      Origin: 'https://www.enbw.com'
      Referer: 'https://www.enbw.com/'
Use Developer Tools → Network, open the charging point in question (xxxxx) and look at the headers to get the subscription key (yyyyy).
This is one way…
The other way is to use the Google API that enwb is using, you can also find it there :slight_smile:
Sent me a message if you need one .
Hi djartistic!
Could you please share the API information for Google? Now I use ENBW, but the past weeks the map is not updating correctly. Most of the time it shows that a charger is available, when it’s not.
I would like to change to Google, I think that will work better :).
Thanks!
Hi, do you have more information on this? Thanks a lot!
More infos on that will be greatly appreciated
Try the shell recharge integration.
