Hey Guys,
I have made my HomeAssistant externally accessible.
I am using an Apache server as a reverse proxy that already manages other applications.
So I also integrated the HomeAssistant into it.
Communication between HA and Apache is unencrypted via port 8123.
The Communication to the reverseproxy is ssl encrypted via port 433.
To avoid having to use a different URL internally than externally, I have also created an internal DNS zone for my external domain.
This means exactly
URL: ha.example.com
Externally, for example, the IP “99.99.99.99” is resolved.
→ My Firewall wich redirects the traffic to the reverseproxy
Internally, the IP “20.10.10.10” is resolved.
→ My reverseproxy
In both cases, however, the communication runs via the ReverseProxy to my HomeAssistant Server.
Does HomeAssistant have any problem with such a configuration?
Do I have to configure the internal and external URL in any way?
There is another DNS entry for homeassistant.example.com. Here the IP “20.10.10.11” is resolved.
→ My HomeAssistant Server
http:
base_url: https://homeassistant.example.com
use_x_forwarded_for: true
trusted_proxies:
- 20.10.10.10
ip_ban_enabled: true
login_attempts_threshold: 5
