Hey all, looking for a little guidance with working with a template.
{{ state_attr('binary_sensor.jarvis_server', 'arrayTotalSpace') }}
results in 51 TB.
How would I get it to give me just 51 and not the full 51 TB
results in 51 TB.
You could have searched the forum, plenty examples…try this in devtools > template
{{ '51 TB'[:2] }}
This slices off the last three characters of the string and reports whatever remains.
{{ state_attr('binary_sensor.jarvis_server', 'arrayTotalSpace')[:-3] }}
Reference: Python String Slicing
Yeah…3… indeed
Thank you!!! Worked perfect
This is the correct solution! You can also split by string:
...'blah').split()[0]
This gives you the first part before the space in the string.
You can also use replace
like this:
{{ state_attr('binary_sensor.jarvis_server', 'arrayTotalSpace').replace(' TB', '') }}
However, the most concise method is to simply slice off the last 3 characters using [:-3]
. Using [:2]
will return the first 2 characters and assumes the desired value will never exceed 2 characters.
