You can connect output of your node directly to Entity node, configured to be a sensor.
Node red will create all sensors for you.
Here is an proof of concept using inject node istead of your node which produces mentioned by you json object
[{"id":"29405a733b05159f","type":"inject","z":"d36bc71f.81d9c8","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\"consumption\":733.572,\"battery\":{\"soc\":52,\"load\":100}}","payloadType":"json","x":330,"y":100,"wires":[["36b4bea2a447c8be","b6a44a9d60cf6303"]]},{"id":"36b4bea2a447c8be","type":"ha-entity","z":"d36bc71f.81d9c8","name":"test_battery_soc","server":"6cdd0bc8.b8e434","version":1,"debugenabled":false,"outputs":1,"entityType":"sensor","config":[{"property":"name","value":"test_battery_soc"},{"property":"device_class","value":"battery"},{"property":"icon","value":""},{"property":"unit_of_measurement","value":"%"}],"state":"payload.battery.soc","stateType":"msg","attributes":[],"resend":true,"outputLocation":"payload","outputLocationType":"none","inputOverride":"allow","outputOnStateChange":false,"outputPayload":"$entity().state ? \"on\": \"off\"","outputPayloadType":"jsonata","x":610,"y":120,"wires":[[]]},{"id":"b6a44a9d60cf6303","type":"ha-entity","z":"d36bc71f.81d9c8","name":"test_consumption","server":"6cdd0bc8.b8e434","version":1,"debugenabled":false,"outputs":1,"entityType":"sensor","config":[{"property":"name","value":"test_consumption"},{"property":"device_class","value":"energy"},{"property":"icon","value":""},{"property":"unit_of_measurement","value":"kWh"}],"state":"payload.consumption","stateType":"msg","attributes":[],"resend":true,"outputLocation":"payload","outputLocationType":"none","inputOverride":"allow","outputOnStateChange":false,"outputPayload":"$entity().state ? \"on\": \"off\"","outputPayloadType":"jsonata","x":620,"y":70,"wires":[[]]},{"id":"6cdd0bc8.b8e434","type":"server","name":"HA MaXyM","version":1,"legacy":false,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true}]
You need to create and configure each sensor manually (AFAIK there is no way to configure them in generic way, based on incoming data). Example above shows more or less how to do that. See that state field has to contain a ‘path’ to particular attribute from your json
And there are sensor device classes you can chose from
