There are lots of hardware sensors in modern computers and I was looking for something that would read the sensors and post them to MQTT so I could monitor them and have the system react to changes.
Thanks for the share, there is too the existing snmp component in HA to retrieve datas from computer/network equipments (use it to get data from my router in HA
While it is true you could use SNMP, it is not something that is configured by default and the SNMP lm-sensors mib is an addon. It also requires direct connectivity between the HA server and the server you wish to pull SNMP from. I have a lot of experience monitoring and working with SNMP and can tell you that many seasoned admins struggle when asked to extend the SNMP MIB with added features. Don’t get me wrong, it works great when the MIB is pre-defined for a specific piece of hardware like a router but when using it with general computing equipment it becomes a pain.
