Pulling in icon for Sensor
I’m pulling in a temperature to Home Assistant using the Sensor node. I’ve defined the icon in Node Red but Home Assistant isn’t displaying the icon.
I haven’t done anything in Home Assistant apart from activating the integration and adding the sensor badge & entity card.
Is this supposed to work or it is something that doesn’t come across?
Thanks!
Try mdi:pool
Question: Sandy, I’ve looked within NR Pallete manager and I can’t locate/see the ‘Sensor node’ you are referring to above. Can you provide the name of the node eg. node-red-contrib-home-assistant-websocket where the ‘Sensor node’ is located? Thank you!
Thanks SigP, this was the problem. Appreciate it!
It is the node-red-contrib-home-assistant-websocket you referred to. Maybe it’s because I’m using an older palette as I don’t see it under the node list there, but it’s definitely on my palette to the left.
Thanks for your clarification, yes that appears to be the reason :+1:t3:
