Hi Guys
I have the following program - https://www.hwinfo.com/forum/threads/introducing-remote-sensor-monitor-a-restful-web-server.1025/page-3 that pulls info from HWINFO and exports the following to a webserver at http://192.168.104.141:55555
“SensorApp”: “HWiNFO”,
“SensorClass”: "GPU [#0 ]: NVIDIA GeForce RTX 3080 Ti: ",
“SensorName”: “GPU Memory Junction Temperature”,
“SensorValue”: “88”,
“SensorUnit”: “°C”,
“SensorUpdateTime”: 1648456286
I believe I need to use the REST sensor in home assistant but I am not understanding what to do. Could someone please post a yaml config that would create a sensor updated by the temperature above. I have tried myself but am failing.
Thanks so much
This is the error I am getting in my logs
Logger: homeassistant.helpers.template
Source: helpers/template.py:1822
First occurred: 11:03:36 (2 occurrences)
Last logged: 11:04:06
Template variable warning: ‘list object’ has no attribute ‘SensorValue’ when rendering ‘{{ value_json.SensorValue }}’
This is the sensor in my configuration.yaml file
- platform: rest
resource: http://192.168.104.141:55555
value_template: "{{ value_json.SensorValue }}"
koying
(Chris B)
March 29, 2022, 7:55am
3
The returned json is an array (enclosed in “[]”) so
{{ value_json[0].SensorValue }}
Thanks for your reply. I had managed to get it working with the following:
- platform: rest
method: GET
scan_interval: 6
value_template: "{{ (value | from_json)[0].SensorValue | int(0) }}"
unit_of_measurement: °C
I appreciate your help though!
