we5ty
(We5ty)
March 30, 2022, 1:37pm
1
I’m trying to set up a simple light switch, using a relay, connected to D2 (GPIO 04), but am unable to get it to show in Lovelace UI. The device shows as online in the ESPHome dash, but I can’t add it to Lovelace, I get an error “Can’t connect to ESP. PLease make sure you YAML file contains an ‘api’ file”.
Any help greatly appreciated.
To start with, it would be very helpful to see your config.
Or check that you have the api enabled in your config, see here .
api:
koying
(Chris B)
March 30, 2022, 1:51pm
3
Assuming it has, I see a lot of complains regarding “.local” addresses, which esphome uses IIRC, not reliably working in HAOS / supervised environments recently…
we5ty
(We5ty)
March 30, 2022, 2:00pm
4
This is the latest attempt:
esphome:
esp8266:
board: nodemcuv2
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
password: "8fbc44c3ba1c76a510e49fdf719c8dd3"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Patio-Lights Fallback Hotspot"
password: "cAzE564dUUTE"
captive_portal:
output:
- platform: gpio
pin: D2
tom_l
March 30, 2022, 2:23pm
5
Read the warning:
Use a switch instead of an output. Also give it a name. Components without names are hidden from home assistant.
Looks good, not very helpful, but I actually just copied your config and uploaded it to one my nodes, and it worked, no issues, maybe an IP Address conflict?, try assigning a static address?
I don’t think he is able to get it added to HA
we5ty
(We5ty)
March 30, 2022, 2:41pm
8
You got further than I did, it didn’t show in the ESPHome integration card.
Just trying the suggestion about using light and name etc.
Thanks all for your help so far.
aceindy
(Aceindy)
9
api:
password: !secret api_password
you can either use a secret, or just type something.
Since i use the same for all my esp’s i find using the secret easier
and when adding it to esphome it will ask you for the api password.
After that it will be added to ha
Works with or without api password.
we5ty
(We5ty)
March 30, 2022, 2:49pm
11
Still get the same error with this config: using patio-lights as host when adding the integration, leaving the port as 6053
esphome:
esp8266:
board: nodemcuv2
# Enable logging
logger:
api:
ota:
wifi:
ap:
captive_portal:
light:
- platform: binary
output: light_output
output:
- id: light_output
platform: gpio
patio-lights.local?
Which board/node are you using?
Not a requirement for either, I just did it a couple times as above without, and added to HA each time.
password (Optional, string): The password to protect the API Server with. Defaults to no password.
Configuration Variables
we5ty
(We5ty)
March 30, 2022, 5:05pm
15
Success! The final issue seem to be wrong/incompletehost name. Noob stuff huh!
Thank you very much to everyone who helped.
