Am running a Zigbee network on Conbee 2 with 9 devices (6 hue lightbulbs, 1 Tradfri bulb and 2 Aqara sensors). I have been trying to add devices to the Zigbee network (hue wall plug, hue lightsbulbs). Pairing works flawless but < minute after pairing they will become unresponsive. I have reset all devices to factory state, tried pairing/unpairing them to Hue bridge, updating the firmware, rebooting the server etc. Every time it is the same: the initial 9 devices work perfectly and all newly paired devices are unresponsive. Can anyone tell me what I am doing wrong? Find below the log of me re-adding a new device ( LWA017) and becoming unresponsive.
New device 0x7b2f (00:17:88:01:0b:36:5b:23) joined the network
[0x7b2f] Scheduling initialization
Received frame on uninitialized device <Device model=None manuf=None nwk=0x7B2F ieee=00:17:88:01:0b:36:5b:23 is_initialized=False> from ep 0 to ep 0, cluster 19: b'\x81/{#[6\x0b\x01\x88\x17\x00\x8e'
[0x7b2f:zdo] ZDO request ZDOCmd.Device_annce: [0x7B2F, 00:17:88:01:0b:36:5b:23, 142]
Tries remaining: 3
[0x7b2f] Requesting 'Node Descriptor'
Tries remaining: 2
[0x7b2f] Extending timeout for 0x9b request
Received frame on uninitialized device <Device model=None manuf=None nwk=0x7B2F ieee=00:17:88:01:0b:36:5b:23 is_initialized=False> from ep 0 to ep 0, cluster 2: b'\x82\x00\x00'
[0x7b2f:zdo] ZDO request ZDOCmd.Node_Desc_req: [0x0000]
[0x7b2f:zdo] No handler for ZDO request:ZDOCmd.Node_Desc_req([0x0000])
Received frame on uninitialized device <Device model=None manuf=None nwk=0x7B2F ieee=00:17:88:01:0b:36:5b:23 is_initialized=False> from ep 0 to ep 0, cluster 32770: b'\x9b\x00/{\x01@\x8e\x0b\x10R\x80\x00\x00,\x80\x00\x00'
[0x7b2f] Got Node Descriptor: NodeDescriptor(logical_type=<LogicalType.Router: 1>, complex_descriptor_available=0, user_descriptor_available=0, reserved=0, aps_flags=0, frequency_band=<FrequencyBand.Freq2400MHz: 8>, mac_capability_flags=<MACCapabilityFlags.AllocateAddress|RxOnWhenIdle|MainsPowered|FullFunctionDevice: 142>, manufacturer_code=4107, maximum_buffer_size=82, maximum_incoming_transfer_size=128, server_mask=11264, maximum_outgoing_transfer_size=128, descriptor_capability_field=<DescriptorCapability.NONE: 0>, *allocate_address=True, *is_alternate_pan_coordinator=False, *is_coordinator=False, *is_end_device=False, *is_full_function_device=True, *is_mains_powered=True, *is_receiver_on_when_idle=True, *is_router=True, *is_security_capable=False)
[0x7b2f] Discovering endpoints
Tries remaining: 3
Received frame on uninitialized device <Device model=None manuf=None nwk=0x7B2F ieee=00:17:88:01:0b:36:5b:23 is_initialized=False> from ep 0 to ep 0, cluster 32773: b'\x9d\x00/{\x02\x0b\xf2'
[0x7b2f] Discovered endpoints: [11, 242]
[0x7b2f] Initializing endpoints [<Endpoint id=11 in=[] out=[] status=<Status.NEW: 0>>, <Endpoint id=242 in=[] out=[] status=<Status.NEW: 0>>]
[0x7b2f:11] Discovering endpoint information
Tries remaining: 3
Received frame on uninitialized device <Device model=None manuf=None nwk=0x7B2F ieee=00:17:88:01:0b:36:5b:23 is_initialized=False> from ep 0 to ep 0, cluster 32772: b'\x9f\x00/{\x1c\x0b\x04\x01\x01\x01\x01\t\x00\x00\x03\x00\x04\x00\x05\x00\x06\x00\x08\x00\x00\x10\x03\xfc\x02\xfc\x01\x19\x00'
[0x7b2f:11] Discovered endpoint information: SizePrefixedSimpleDescriptor(endpoint=11, profile=260, device_type=257, device_version=1, input_clusters=[0, 3, 4, 5, 6, 8, 4096, 64515, 64514], output_clusters=[25])
[0x7b2f:242] Discovering endpoint information
Tries remaining: 3
Received frame on uninitialized device <Device model=None manuf=None nwk=0x7B2F ieee=00:17:88:01:0b:36:5b:23 is_initialized=False> from ep 0 to ep 0, cluster 32772: b'\xa1\x00/{\n\xf2\xe0\xa1a\x00\x00\x00\x01!\x00'
[0x7b2f:242] Discovered endpoint information: SizePrefixedSimpleDescriptor(endpoint=242, profile=41440, device_type=97, device_version=0, input_clusters=[], output_clusters=[33])
[0x7b2f:11:0x0000] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=163 command_id=Command.Read_Attributes_rsp>
[0x7b2f] Read model 'LWA017' and manufacturer 'Signify Netherlands B.V.' from <Endpoint id=11 in=[basic:0x0000, identify:0x0003, groups:0x0004, scenes:0x0005, on_off:0x0006, level:0x0008, lightlink:0x1000, manufacturer_specific:0xFC03, manufacturer_specific:0xFC02] out=[ota:0x0019] status=<Status.ZDO_INIT: 1>>
[0x7b2f] Discovered basic device information for <Device model='LWA017' manuf='Signify Netherlands B.V.' nwk=0x7B2F ieee=00:17:88:01:0b:36:5b:23 is_initialized=True>
Device is initialized <Device model='LWA017' manuf='Signify Netherlands B.V.' nwk=0x7B2F ieee=00:17:88:01:0b:36:5b:23 is_initialized=True>
Checking quirks for Signify Netherlands B.V. LWA017 (00:17:88:01:0b:36:5b:23)
Considering <class 'zhaquirks.xbee.xbee_io.XBeeSensor'>
Fail because endpoint list mismatch: {232, 230} {242, 11}
Considering <class 'zhaquirks.xbee.xbee3_io.XBee3Sensor'>
Considering <class 'zhaquirks.smartthings.tag_v4.SmartThingsTagV4'>
Fail because endpoint list mismatch: {1} {242, 11}
Considering <class 'zhaquirks.smartthings.multi.SmartthingsMultiPurposeSensor'>
Considering <class 'zhaquirks.netvox.z308e3ed.Z308E3ED'>
Considering <class 'zhaquirks.gledopto.soposhgu10.SoposhGU10'>
Fail because endpoint list mismatch: {11, 13} {242, 11}
Considering <class 'bellows.zigbee.application.EZSPCoordinator'>
device - 0x7B2F:00:17:88:01:0b:36:5b:23 entering async_device_initialized - is_new_join: True
device - 0x7B2F:00:17:88:01:0b:36:5b:23 has joined the ZHA zigbee network
[0x7B2F](LWA017): started configuration
[0x7B2F:ZDO](LWA017): 'async_configure' stage succeeded
[0x7B2F:11:0x0000]: finished channel configuration
Error handling '_save_attribute' event with (00:17:88:01:0b:36:5b:23, 11, 0, 4, 'Signify Netherlands B.V.') params: FOREIGN KEY constraint failed
Error handling '_save_attribute' event with (00:17:88:01:0b:36:5b:23, 11, 0, 5, 'LWA017') params: FOREIGN KEY constraint failed
[0x7B2F:11:0x0006]: bound 'on_off' cluster: Status.SUCCESS
[0x7B2F:11:0x0008]: bound 'level' cluster: Status.SUCCESS
[0x7b2f:11:0x1000] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=169 command_id=Command.Default_Response>
[0x7B2F:11:0x0019]: finished channel configuration
[0x7b2f:11:0x0006] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=171 command_id=Command.Configure_Reporting_rsp>
[0x7B2F:11:0x0006]: Successfully configured reporting for '{'on_off': (0, 900, 1)}' on 'on_off' cluster: [ConfigureReportingResponseRecord(status=0)]
[0x7B2F:11:0x0006]: finished channel configuration
[0x7b2f:11:0x0008] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=173 command_id=Command.Configure_Reporting_rsp>
[0x7B2F:11:0x0008]: Successfully configured reporting for '{'current_level': (1, 900, 1)}' on 'level' cluster: [ConfigureReportingResponseRecord(status=0)]
[0x7B2F:11:0x0008]: finished channel configuration
[0x7B2F:11:0x0006]: 'async_configure' stage succeeded
[0x7B2F:11:0x0008]: 'async_configure' stage succeeded
[0x7B2F:11:0x0000]: 'async_configure' stage succeeded
[0x7B2F:11:0x1000]: 'async_configure' stage failed: not enough values to unpack (expected 3, got 2)
[0x7B2F:11:0x0019]: 'async_configure' stage succeeded
[0x7B2F](LWA017): completed configuration
[0x7B2F](LWA017): stored in registry: ZhaDeviceEntry(name='Signify Netherlands B.V. LWA017', ieee='00:17:88:01:0b:36:5b:23', last_seen=1642840255.316158)
[0x7b2f:11:0x0003] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=175 command_id=Command.Default_Response>
[0x7B2F:11:0x0003]: executed 'trigger_effect' command with args: '(2, 0)' kwargs: '{}' result: [64, <Status.SUCCESS: 0>]
[0x7B2F](LWA017): started initialization
[0x7B2F:ZDO](LWA017): 'async_initialize' stage succeeded
[0x7B2F:11:0x0006]: initializing channel: from_cache: False
[0x7B2F:11:0x0008]: initializing channel: from_cache: False
[0x7B2F:11:0x0000]: initializing channel: from_cache: False
[0x7B2F:11:0x0000]: finished channel initialization
[0x7B2F:11:0x1000]: initializing channel: from_cache: False
[0x7B2F:11:0x1000]: finished channel initialization
[0x7B2F:11:0x0019]: initializing channel: from_cache: False
[0x7B2F:11:0x0019]: finished channel initialization
[0x7b2f:11:0x0006] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=177 command_id=Command.Read_Attributes_rsp>
[0x7B2F:11:0x0006]: finished channel initialization
[0x7b2f:11:0x0008] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=179 command_id=Command.Read_Attributes_rsp>
[0x7B2F:11:0x0008]: received attribute: 0 update with value: 254
[0x7B2F:11:0x0008]: finished channel initialization
[0x7B2F:11:0x0006]: 'async_initialize' stage succeeded
[0x7B2F:11:0x0008]: 'async_initialize' stage succeeded
[0x7B2F:11:0x0000]: 'async_initialize' stage succeeded
[0x7B2F:11:0x1000]: 'async_initialize' stage succeeded
[0x7B2F:11:0x0019]: 'async_initialize' stage succeeded
[0x7B2F](LWA017): power source: Mains
[0x7B2F](LWA017): completed initialization
None: polling current state
[0x7b2f:11:0x0006] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=181 command_id=Command.Read_Attributes_rsp>
[0x7b2f:11:0x0008] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=183 command_id=Command.Read_Attributes_rsp>
[0x7b2f:11:0x0008] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=0 command_id=Command.Report_Attributes>
[0x7b2f:11:0x0008] ZCL request 0x000a: [[Attribute(attrid=0, value=<TypeValue type=uint8_t, value=254>)]]
[0x7b2f:11:0x0008] Attribute report received: current_level=254
[0x7b2f:11:0x0006] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=1 command_id=Command.Report_Attributes>
[0x7b2f:11:0x0006] ZCL request 0x000a: [[Attribute(attrid=0, value=<TypeValue type=Bool, value=Bool.true>)]]
[0x7b2f:11:0x0006] Attribute report received: on_off=1
[0xFC90](TRADFRI bulb E27 WS opal 980lm): Attempting to checkin with device - missed checkins: 2
[0xfc90] Delivery error for seq # 0xb9, on endpoint id 1 cluster 0x0000: message send failure
Device 0x7b2f (00:17:88:01:0b:36:5b:23) joined the network
[0x7b2f] Delivery error for seq # 0xbb, on endpoint id 11 cluster 0x0004: message send failure
[0x7b2f:11] Failed to sync-up group membership
[0x7b2f:11:0x0004] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=CLUSTER_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=187 command_id=2>
[0x7b2f:11:0x0004] ZCL request 0x0002: [25, []]
[0x7b2f:11:0x0004] No handler for cluster command 2
Device 0x4c4f (00:17:88:01:0b:36:5b:23) joined the network
Device 00:17:88:01:0b:36:5b:23 changed id (0x4c4f => 0x4c4f)
[0x4c4f] Skipping initialization, device is fully initialized
Device is initialized <Device model='LWA017' manuf='Signify Netherlands B.V.' nwk=0x4C4F ieee=00:17:88:01:0b:36:5b:23 is_initialized=True>
[0x4c4f:zdo] ZDO request ZDOCmd.Device_annce: [0x4C4F, 00:17:88:01:0b:36:5b:23, 142]
device - 19535:00:17:88:01:0b:36:5b:23 entering async_device_initialized - is_new_join: False
device - 19535:00:17:88:01:0b:36:5b:23 has been reset and re-added or its nwk address changed
skipping discovery for previously discovered device - 19535:00:17:88:01:0b:36:5b:23
[19535](LWA017): started configuration
[19535:ZDO](LWA017): 'async_configure' stage succeeded
[19535:11:0x0000]: finished channel configuration
Device 00:17:88:01:0b:36:5b:23 already exists. Updating it.
[0x4c4f:zdo] ZDO request ZDOCmd.Node_Desc_req: [0x0000]
[0x4c4f:zdo] No handler for ZDO request:ZDOCmd.Node_Desc_req([0x0000])
[19535:11:0x0008]: bound 'level' cluster: Status.SUCCESS
[19535:11:0x0006]: bound 'on_off' cluster: Status.SUCCESS
[0x4c4f:11:0x1000] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=193 command_id=Command.Default_Response>
[19535:11:0x0019]: finished channel configuration
[0x4c4f:11:0x0008] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=195 command_id=Command.Configure_Reporting_rsp>
[19535:11:0x0008]: Successfully configured reporting for '{'current_level': (1, 900, 1)}' on 'level' cluster: [ConfigureReportingResponseRecord(status=0)]
[19535:11:0x0008]: finished channel configuration
[0x4c4f:11:0x0006] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=197 command_id=Command.Configure_Reporting_rsp>
[19535:11:0x0006]: Successfully configured reporting for '{'on_off': (0, 900, 1)}' on 'on_off' cluster: [ConfigureReportingResponseRecord(status=0)]
[19535:11:0x0006]: finished channel configuration
[19535:11:0x0006]: 'async_configure' stage succeeded
[19535:11:0x0008]: 'async_configure' stage succeeded
[19535:11:0x0000]: 'async_configure' stage succeeded
[19535:11:0x1000]: 'async_configure' stage failed: not enough values to unpack (expected 3, got 2)
[19535:11:0x0019]: 'async_configure' stage succeeded
[19535](LWA017): completed configuration
[19535](LWA017): stored in registry: ZhaDeviceEntry(name='Signify Netherlands B.V. LWA017', ieee='00:17:88:01:0b:36:5b:23', last_seen=1642840293.571896)
[0x4c4f:11:0x0003] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=199 command_id=Command.Default_Response>
[19535:11:0x0003]: executed 'trigger_effect' command with args: '(2, 0)' kwargs: '{}' result: [64, <Status.SUCCESS: 0>]
[19535](LWA017): started initialization
[19535:ZDO](LWA017): 'async_initialize' stage succeeded
[19535:11:0x0006]: initializing channel: from_cache: False
[19535:11:0x0008]: initializing channel: from_cache: False
[19535:11:0x0000]: initializing channel: from_cache: False
[19535:11:0x0000]: finished channel initialization
[19535:11:0x1000]: initializing channel: from_cache: False
[19535:11:0x1000]: finished channel initialization
[19535:11:0x0019]: initializing channel: from_cache: False
[19535:11:0x0019]: finished channel initialization
[0x4c4f:11:0x0006] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=201 command_id=Command.Read_Attributes_rsp>
[19535:11:0x0006]: finished channel initialization
[0x4c4f:11:0x0008] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=203 command_id=Command.Read_Attributes_rsp>
[19535:11:0x0008]: received attribute: 0 update with value: 254
[19535:11:0x0008]: finished channel initialization
[19535:11:0x0006]: 'async_initialize' stage succeeded
[19535:11:0x0008]: 'async_initialize' stage succeeded
[19535:11:0x0000]: 'async_initialize' stage succeeded
[19535:11:0x1000]: 'async_initialize' stage succeeded
[19535:11:0x0019]: 'async_initialize' stage succeeded
[19535](LWA017): power source: Mains
[19535](LWA017): completed initialization
[0x4c4f:11:0x0008] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=0 command_id=Command.Report_Attributes>
[0x4c4f:11:0x0008] ZCL request 0x000a: [[Attribute(attrid=0, value=<TypeValue type=uint8_t, value=254>)]]
[0x4c4f:11:0x0008] Attribute report received: current_level=254
[0x4c4f:11:0x0006] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=1 command_id=Command.Report_Attributes>
[0x4c4f:11:0x0006] ZCL request 0x000a: [[Attribute(attrid=0, value=<TypeValue type=Bool, value=Bool.true>)]]
[0x4c4f:11:0x0006] Attribute report received: on_off=1
[0xabaa:11:0x0008] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=202 command_id=Command.Report_Attributes>
[0xabaa:11:0x0008] ZCL request 0x000a: [[Attribute(attrid=0, value=<TypeValue type=uint8_t, value=140>)]]
[0xabaa:11:0x0008] Attribute report received: current_level=140
[0xABAA:11:0x0008]: received attribute: 0 update with value: 140
[0x3c43:1:0x0000] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=True is_reply=True disable_default_response=True> manufacturer=4447 tsn=26 command_id=Command.Report_Attributes>
[0x3c43:1:0x0000] ZCL request 0x000a: [[Attribute(attrid=65281, value=<TypeValue type=LVBytes, value=b'\x01!\xd1\x0b\x03(\x15\x04!\xa8\x13\x05!\x17\x00\x06$*\x00\x00\x01\x01\n!\x00\x00d\x10\x00'>)]]
[0x3c43:1:0x0000] Attribute report received: 65281=b'\x01!\xd1\x0b\x03(\x15\x04!\xa8\x13\x05!\x17\x00\x06$*\x00\x00\x01\x01\n!\x00\x00d\x10\x00'
[0x3c43:1:0x0001] Voltage mV: [Min]:2820 < [RAW]:3025 < [Max]:3100, Battery Percent: 73.0
[0x6a80:2:0x0012] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=0 command_id=Command.Report_Attributes>
[0x6a80:2:0x0012] ZCL request 0x000a: [[Attribute(attrid=85, value=<TypeValue type=uint16_t, value=2>)]]
[0x6a80:2:0x0012] Attribute report received: present_value=2
Error handling '_save_attribute' event with (00:15:8d:00:04:87:8b:a9, 2, 18, 0, None) params: NOT NULL constraint failed: attributes_cache_v7.value
light.tv_spot_2: polling current state
[0xe2aa:11:0x0006] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=205 command_id=Command.Read_Attributes_rsp>
[0xe2aa:11:0x0008] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=207 command_id=Command.Read_Attributes_rsp>
[0xE2AA:11:0x0008]: received attribute: 0 update with value: 140
[0xe2aa:11:0x0300] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=209 command_id=Command.Read_Attributes_rsp>
light.tv_spot_3: polling current state
[0xabaa:11:0x0006] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=211 command_id=Command.Read_Attributes_rsp>
[0xabaa:11:0x0008] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=213 command_id=Command.Read_Attributes_rsp>
[0xabaa:11:0x0300] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=215 command_id=Command.Read_Attributes_rsp>
