Hi!
I’m looking into a solution that will allow me to periodically pull the SSL certificates from another host and apply them to Home Assistant.
So far, for the pull method, I considered adding a crontab entry that will execute an SCP command with auth-key as a login method. Are there better methods to achieve this?
I assume, I’ll have to add the folowint to my configuration.yaml
, is this correct?
http:
base_url: https://hass.example.org
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
Now - how to I apply the certs? Should I add the ha core restart
to crontab, or is there a better way?
Will my crontab entry persist between HassOS updates?
