Hello All. So I’m going to go with HA. I’ve prewired my home for cameras, vid distribution, shades etc. I did not have enough time to run speaker wires so I guess I’ll use a Sonos type of solution. I have Lutron caseta switches. I pulled 3 cat 6, 1 coax and 1 fiber to every tv location.
I have all my wires pulled to where I will build my rack. A few questions.
What are the first things I should be buying as far as hardware for the rack and software?
I thought I heard that there were two options for installing HA software…something to do with Raspberry Pi and a virtual machine…??
Any help would be greatly appreciated. Thank you very much.
Well, rack choices are basically shaped by what you’re planning on buying for the rack. 8U, 22U, 44U… As for the server, you can run HA on a Pi4 with SSD, but if you’re able to get a rack mount server then that’s not a bad choice.
There’s a whole lot more than buy X though. Depends on what you want to run, whether you’re thinking of a NAS type setup, your budget…
There’s four main install options, and if you’re looking purely at Home Assistant OS then you’ve got the options of running directly on a Pi (or similar) or in a VM.
What do you mean by rack mounted server? I do kind of know what a server is but not sure how that plays into HA. What would that enable? I’m not very familiar with this stuff but willing to learn for sure, thank you.
Get a cheap/medium range NUC for HA. Works flawless and is well-powered for the future as well.
For networking a lot of HA users (myself included) use Unifi gear, its cheapish and decently configurable with an ok UI.
This has cropped up many times and would not be a good solution, if you buy zigbee bulbs like hue or tradfri, how would you like to pay your guy €250/$250 to change a bulb for you everytime a bulb goes ?
A NUC is an Intel term for the ‘next unit of computing’ - just their term for a very small form factor pc that was built to attach to the vesa mounts on the back of modern flat screen monitors.
I recommend that you just start with a Pi4b 4G run with it for 6 months to decide if this is for you or not then you can invest in better hardware as your wish, but probably 90% of users a happy long term with a €60 PI (admittedly there’s also the case, the power supply, an uSD card and a dongle if you go z-wave or zigbee but ALL that can still be had for less than €120
If you rush out and buy something you will likely find that it doesn’t fit your needs. A RasPi 4 or old laptop/desktop is good starting point for someone that has never had this type hardware. After one time you will learn your needs and can buy appropriately vs buy and try to make it work.
Home Assistant is free software. It is used by tens of thousands of home automation enthusiasts. There are many resources available to learn it, ranging from the official documentation, to blogs, video tutorials, even podcasts. It’s very much a DIY thing.
However, if you want to hire someone to serve as a tutor, I imagine someone will take your offer. Good luck!
Yes. Well, any device with a web browser really. Phone or tablet also works well and there are apps for Home Assistant. A computer is certainly easier when entering configuration info
You need some sort of device to actually run the Home Assistant software. That can be one of many choices: RPi, NUC, laptop, server machine etc. As suggested above, since you are starting out a RPi is a nice simple and cheap entry level device to run Home Assistant.
Home Assistant runs ‘headless’ so you can’t just plug a monitor and keyboard into the device running HA (Home Assistant) to view / configure it. Once it’s installed you never need to physically access that device again unless you want to unplug it.
Once its up and running you will ‘view’ the HA interface and do all your configuration via a web browser from another device, ie: another PC, phone, tablet etc.
I started off running HA on a RPi3 but upgraded to a NUC when I wanted to use it to also record my CCTV cameras. A RPi simply doesn’t have the processing power for that kind of load.
