Hello!
I am new here in the community and als a newbie acc. ESP.
I started a new project, counting my power-pulses with an energy-meter and S0 interface.
My energy-meter is this model: ORNO OR-WE-520 with 800 imp/kWh
I am using an AZDelivery D1 Mini NodeMcu ESP8266
I collected some infomation by checking some community-platforms, web-sites, youtube-videos and so on.
After some discussions in some communities, I made a wiring acc. this sheme in the screenshot. (s. attached file)
After that, I started the integration in Home Assistant with this YAML-code.
(FYI - I have no idea in YAML-Coding and i just copied some collected codes to one script together!
- Trying to configurate some parameters to my requirements).
esphome:
friendly_name: ESP-Counter-Test
comment: Stromzaehler-Test-01
esp8266:
board: esp01_1m
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "XXX"
password: "XXX"
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "XXX"
ota:
- platform: pulse_counter
pin: GPIO13
unit_of_measurement: 'W'
accuracy_decimals: 2
update_interval: 20s
filters:
- multiply: 75
# - multiply: 0.75 gives kW
total:
unit_of_measurement: 'kWh'
accuracy_decimals: 1
name: 'ESP Stromzähler Test Total'
filters:
- multiply: 0.001
First, i thought the ESP works fine.
But. After some hours, i checked the graph in Home Assistant and it looks like the following screenshots. (s. attached file)
As you can see, there are some “Peaks” in the graphs.
One peak has a maximum of 66kW! This can`t be. (s. attached file)
Soome measured points beginning at 0W till approximately 200W
Some points beginning at 200W till 400W
Some points beginning at 400W till 600W
This is very confusing. (s. attached file)
(FYI - As a new user in this community, I am not allowed uploading more than one attachment - So I have to combine all pictures and screenshot in one file - sorry for that)
Now I have some questions.
- Do you have an idea, why there are som peaks?
- Is the YAML-Code correct?
- Is the wiring correct?
- Do you have some tips for a Home Assistant and ESP newbie?
In sum, I have 6 energy-meters which I am going to count with ESP8266.
And one project, for counting an water-meter.
But first, I’ll try it with this ESP-Test-Counter. And if this works, I can go one step further.
And after that, I am sure, I’ll come back to this community!
In advance, thanks for your answers and tips!
Sigi-77
