Pulse counter ESP32 with YF-B10 - I cant calibrate
Pulser counter ESP32 with YF-B10
I have assembled a YF-B10 flowmeter and doing tests to perform the calibration I have realized that it measures differently depending on the flow that I tap.
I have filled a 0.5 liter bottle by opening the tap with a slow and fast flow.
But the equipment does not repeat the number of pulses that it counts for every 0.5 liters.
Can you tell me if something is missing or is the equipment not working well?I pass you the records of the number of pulses that it registers in 60 seconds, reaching 0.5 liters at different filling speeds.
test 1: 0,5liters → 19 pulsos (tap 25% open)
test 2: 0,5liters → 82 pulsos (tap 100% open)
test 3: 0,5liters → 36 pulsos (tap 50% open)
test 4: 0,5liters → 54 pulsos (tap 50% open)
test 4: 0,5liters → 28 pulsos (tap 25% open)
test 4: 0,5liters → 69 pulsos (tap 100% open)
With this variation of pulses depending on the demand, how can I calibrate the equipment to measure correctly?
  - platform: pulse_counter
    name: "consumo agua litros"
    pin:
      number: GPIO2
      mode: INPUT_PULLUP
    unit_of_measurement: "pulsos"
    icon: "mdi:water"
'[09:44:03][D][pulse_counter:160]: 'consumo agua litros': Retrieved counter: 19.00 pulses/min
[09:44:03][D][sensor:113]: 'consumo agua litros': Sending state 19.00000 pulsos with 2 decimals of accuracy
[09:45:03][D][pulse_counter:160]: 'consumo agua litros': Retrieved counter: 82.00 pulses/min
[09:45:03][D][sensor:113]: 'consumo agua litros': Sending state 82.00000 pulsos with 2 decimals of accuracy
[09:48:03][D][pulse_counter:160]: 'consumo agua litros': Retrieved counter: 36.00 pulses/min
[09:48:03][D][sensor:113]: 'consumo agua litros': Sending state 36.00000 pulsos with 2 decimals of accuracy
[09:51:03][D][pulse_counter:160]: 'consumo agua litros': Retrieved counter: 54.00 pulses/min
[09:51:03][D][sensor:113]: 'consumo agua litros': Sending state 54.00000 pulsos with 2 decimals of accuracy
[09:53:03][D][pulse_counter:160]: 'consumo agua litros': Retrieved counter: 28.00 pulses/min
[09:53:03][D][sensor:113]: 'consumo agua litros': Sending state 28.00000 pulsos with 2 decimals of accuracy
[09:56:03][D][pulse_counter:160]: 'consumo agua litros': Retrieved counter: 69.00 pulses/min
[09:56:03][D][sensor:113]: 'consumo agua litros': Sending state 69.00000 pulsos with 2 decimals of accuracy'
0.5L in one minute is below the specified minimum flow rate for this sensor:
Flow rate : 2~50L/min
You are right, I have calibrated it with 5L / min and the measurement seems to stabilize.
For the one that interests you, I get the following result:
1 liter = 373 pulses (YF-B10)
If there is someone that does not come out similar to indicate it
This function indicates the manufacturer (6 * Q-8) Q) what is it for, once you have it calibrated?
If Q is the number of pulses then then from that equation the number of pulses is not linearly proportional to the flow rate, as assumed by the pulse counter. You will have to apply this:
https://esphome.io/components/sensor/index.html#calibrate-polynomial
I understand what you are saying, but I don’t see much sense that since the flow is not linear, does the formula say that multiplies the flow by 8 and subtracts 6?
new pulses/min= (6 * Q-8)
It does not say under what circumstances to push the regression.
Do you have any examples of similar equipment?
No. Expanded out the formula says flow (L/min) = 6Q² - 8Q.
It’s a quadratic. Hence you need to use calibrate_polynomial, not calibrate_linear.
Use degree 2 as the biggest power is Q squared.
  filters:
    - calibrate_polynomial:
       degree: 2
       datapoints:
        # Map from sensor to true value, use your measurements not this example.
        - 0.0 -> 0.0
        - 10.0 -> 12.1
        - 13.0 -> 14.0
The more data points you have the better. One point is not enough to calibrate a polynomial.
Or you could use a lambda filter expressing the equation:
https://esphome.io/components/sensor/index.html#lambda
filters:
  - lambda: return x * (6 * x - 8);
That would be easier.
I understand how the polynomial works, which seems to me that the polynomial indicated by the manufacturer is not well formulated.
I’ll look at it anyway.
Thank you so much
Hello
I am considering purchasing the YF-B10 to account for water flow. Did you manage to get yours working? Are the measurements reliable?
@fmmsfz don’t expect any answer the next 100 days or even after that…
better than resuscitate old threads is just making use of the (free) search :mag: function this forum offers :+1:
this feels like an old thread, and i might be a little of topic here, but i came across it as it was the closes to what i am looking for.
i just started implementing the same sensor (not sure about the exact same “pulse counter” in it, as mine says its Flow rate : 1~30L/min), and need some help with the calibrations.
can someone share the steps for the calibration?
how do i figure my “lambda returns” filter equation?
i got this sensor of aliexpress, and surprisingly enough - seller does not have any other info to give me as far as “Q” goes. honestly - not really sure what it means myself… so don’t really know what to ask him to find out for me…
so i figured ill try our community instead, and figure this out for ourselves…
:crossed_fingers:
cheers
Would be interested too in some more information
Hi @tom_l
Thank you for that solution! If I write the lambda, I don’t need to do the measurement and write the calibration lines? Right now, I find crazy values ! Like 155 billion liters per minute with the lambda formula you gave.
What happens if the flow is getting more than 50 L per minute ? It is just imprecise but should stay more or less on the same curve, no?
No. The manufacturer has only specified an equation for the range 2-50 L/min. Outside that range it is uncharacterised. It could even stop being proportional.
also about to try and get this flow sensor working
I’, also struggeling with calibration of that device for some time. I follewd approach suggested by @tom_l .
y=Q(6Q-8).
I adapted it to my own project on Arduino as:
return (calibrationDifference+sqrt(pow(calibrationDifference,2)-4*calibrationFactor*(-freqency)))/(2*calibrationFactor);
Pllase just note that for ‘calibrationDifference’ > 0, reading will be > 0 even if no pulse given, so be sure to filter it out.
It’s pretty promissing as I’m getting pretty accurate readings. I can publish the whole code on my GitHub if needed.
