Hi there,
I have a pulse counter connected to an rpi zero which sends its values via MQTT to home assistant running on another hardware component. The MQTT messages look like this:
"fields": {
"nstime": 1640676204429749500,
"pulse": 3911667,
"uptime": 11280557.66
"name": "s0meter",
"tags": {
"host": "s0pi",
"path": "/home/pi/s0readings/sensorlog-current.txt"
"timestamp": 1640676204
The ‘nstime’ and ‘pulse’ fields are the most important ones:
- pulse: the current pulse amount, my s0 meter gives 1000 pulses per kWh
- nstime: the epoch at the time of the pulse
This gives me energy, not power. According to Pulse counter to current usage I should be able to use the derivative component (Derivative - Home Assistant) to calculate power.
However, I have the impression the derivative function will use the time that HA received the MQTT message. This is incorrect in my case: it should use the epoch mentioned in the MQTT message (nstime).
Is there a way to calculate the power manually, using e.g. a template? I guess it should be something like:
W = 1Wh / ( epoch(last_pulse) - epoch(previous_pulse) / 3600 )
