Pulse counter not counting for PWM fan
Hi all,
I just set up the config below. One of the values it reports is the current speed of my fan. But MQTT not sending the right fan speed using the pulse counter. The pulse counter always seems to send 0.0, even when I see the fans in action.
Below is the MQTT-output. You can see that the fan speed is set to 0.219 (calculated from the difference between TempIn and TempOut). The Fans do speed up, but the MQTT pulse count is still 0.0.
Of course the fans are connected using a 4-pin connector. Fans used are Artic F9 PWM. I had this setup running in the past, but it more or less just stopped working :frowning:
Any help is much appreciated.
MQTT-sniffing:
dbebartlinks/debug [D][dallas.sensor:148]: 'DBE Bart Links Temp Out': Got Temperature=19.9°C
dbebartlinks/debug [D][sensor:092]: 'DBE Bart Links Temp Out': Sending state 19.87500 °C with 1 decimals of accuracy
dbebartlinks/debug [D][main:326]:  Fan speed: 0.219 delta_temp: 0.625
dbebartlinks/sensor/dbe_bart_links_temp_out/state 19.9
dbebartlinks/debug [D][pulse_counter:159]: 'DBE Bart Links Fan Speed': Retrieved counter: 0.00 pulses/min
dbebartlinks/debug [D][sensor:092]: 'DBE Bart Links Fan Speed': Sending state 0.00000 RPM with 2 decimals of accuracy
dbebartlinks/sensor/dbe_bart_links_fan_speed/state 0.00
ESPhome config:
esphome:
  platform: ESP32
  board: esp32dev
wifi:
  ssid: "secret"
  password: "secret"
  domain: ".secret"
  fast_connect: on
  power_save_mode: light
globals:
  - id: fanspeed
    type: float
    restore_value: no
    initial_value: '1'
  - id: delta_temp
    type: float
    restore_value: no
    initial_value: '1'
# Enable logging
logger:
#  level: INFO
ota:
dallas:
  - pin: 18
    update_interval: 30s
  - pin: 23
# Sensor for outgoing water
  - platform: dallas
    address: 0x989F16D71964FF28
    name: "DBE Bart Links Temp Out"
    dallas_id: dallas_1
    accuracy_decimals: 1
    unit_of_measurement: "°C"
    on_value:
      then:
# Do not start the fans when tempdifference is below 2 degrees. Also prevents negative values
# Else start. Multiply by 0.03. 30 degrees is the maximum difference between tempIn and TempOut.
# Fanspeed must be a value between 0 and 1
        - lambda: |-
            id(delta_temp) = id(temp_in).state - id(temp_out).state;
            if (id(delta_temp) < 0.5) {
              id(fanspeed) = 0;
            } else {
              id(fanspeed) = (0.35 * id(delta_temp));
        - logger.log:
            format: " Fan speed: %.3f delta_temp: %.3f"
            args: [  'id(fanspeed)', 'id(delta_temp)' ]
        - output.set_level:
            level: !lambda "return id(fanspeed);"
  - platform: dallas
# Sensor for incoming water
    address: 0x80E9DBD71964FF28
    name: "DBE Bart Links Temp In"
    dallas_id: dallas_2
  - platform: pulse_counter
    pin: 22
    name: "DBE Bart Links Fan Speed"
    unit_of_measurement: 'RPM'
    filters:
      - multiply: 0.5
    count_mode:
      rising_edge: DISABLE
      falling_edge: DISABLE
output:
  - platform: ledc
    pin: 21
    frequency: 25000
mqtt:
 port: 1883
 broker: 192.168.0.221
 username: "secret"
 password: secret
 client_id: dbebartlinks
i am facing the same issue
were you able to figure it out ?
