I’ve been using Home Assistant for a while now and I’m looking to integrate our solar panels. The energy meter has a pulse output which I can connect to a KNX binary input module. Is there a way to interpret this signal as an energy meter without using ESPHome?
If you want to play it over Knx there are some binary inputs available that specificity support S0 meter input. These can add the energy / impulse internally and send the value to the bus.
Some solar inverters support that too - so you might also be able to use that.
