I’ve been playing with Chinese 1" pulse flow meter YF-B10. Got it wired up and pulses come pretty OK, some deviation time to time.
But, it keeps showing the last actual flow value, even there is no flow and no pulses. I’ve tried to configure it (and some ChatGPT stuff), but no luck.
My current ESPHome config:
mqtt:
broker: xxx.xxx.xxx.xxxx
port: xxxx
discovery: true
discovery_prefix: homeassistant
globals:
- id: cumulative_pulses
type: float
restore_value: true # Persist across reboots
initial_value: '0.0'
- platform: pulse_meter
pin: GPIO21
unit_of_measurement: "L/min"
accuracy_decimals: 1
state_class: measurement
internal_filter: 5ms
timeout: 1s # Mark flow as 0 after 1 second without pulses
force_update: true # Force MQTT to send 0 when no pulses are detected
filters:
- lambda: |-
if (x == 0) return 0.0; // If no pulses, return 0
if (x < 709) return 0.0; // Ignore flow below 2 L/min (corresponding to 709 pulses/min)
return ((x - 709) / 354.8) + 2.0; // Apply calibration: 354.8 pulses/L, threshold at 2 L/min
- throttle: 1s # Limit updates to every 1 second
- sliding_window_moving_average:
window_size: 5
send_every: 1
- clamp:
min_value: 0.0
max_value: 30.0 # Adjust for max sensor capacity
unit_of_measurement: "L"
accuracy_decimals: 2
state_class: total_increasing # Required for HA Energy dashboard
lambda: |-
// Convert the cumulative pulses to liters
return (id(cumulative_pulses) * 0.002817);
interval:
- interval: 1s
then:
- lambda: |-
// Add the current raw pulse count to the cumulative total
id(cumulative_pulses) += id(flow_rate).state;
I thought that timeout: 1s should have worked, but no.
Those straight lines in chart don’t have any updates in between.
I made template sensor in config.yaml to fix it. This helps a bit, but there are still some ghost remains 5-50 sec after no flow:
template:
- sensor:
- name: "Flow Rate Corrected"
state: >-
{% set last_change = as_timestamp(states.sensor.flowmeter_esp_flow_rate.last_changed) %}
{% set time_now = as_timestamp(now()) %}
{% set flow_rate = states('sensor.flowmeter_esp_flow_rate') | float(0) %}
{% if (time_now - last_change) > 2 or flow_rate == 0 %}
0
{% else %}
{{ flow_rate }}
{% endif %}
availability: >-
{{ states('sensor.flowmeter_esp_flow_rate') not in ['unknown', 'unavailable', 'none'] }}
