After hours of frustration and apparently a complete lack of understanding of the available options, I need assistance with pulse width modulation control of several relays on an 8 relay esp8266 pcf_expander. The relays are configured as binary lights.
The relay board is controlling pneumatic valves that fill or purge air from the air bags on my motorhome to keep it level based on output from an accelerometer. The code works perfectly (if not elegantly) however the rear airbags have approximately twice the volume as the fronts so it takes twice as long to fill them. Thus, I want to modulate the front relays to @ 50% ON time then tweak the percentage from there so the front and rear rise or fall at the same rate.
I have tried to configure both esp8266_pwm and slow_pwm with no sucesss. The closest I got was having the relay modulate constantly (at my desired % on/off time) with no on/off control from the code. I have not included any of my numerous attempts below as they didn’t work but have included the current esphome config from the board and a snippet of the relevant script code that is properly controlling the relays without the required modulation.
Any assistance is humbly accepted and greatly appreciated!!
ESP8266/pcf_expander
esphome:
friendly_name: 8CH_Relay
esp8266:
board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "NNNNNNNN"
ota:
password: "NNNNNNNN"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "8Ch-Relay Fallback Hotspot"
password: "NNNNNNN"
captive_portal:
i2c:
sda: 4
scl: 5
scan: true
pcf8574:
- id: pcf_expander
address: 0x27
light:
- platform: binary
output: relay_7
- platform: binary
output: relay_6
- platform: binary
output: relay_5
- platform: binary
output: relay_4
- platform: binary
output: relay_3
- platform: binary
output: relay_2
- platform: binary
output: relay_1
- platform: binary
output: relay_0
output:
- platform: gpio
pin:
pcf8574: pcf_expander
number: 0
# One of INPUT, INPUT_PULLUP or OUTPUT
mode: OUTPUT
inverted: True
- platform: gpio
pin:
number: 1
mode: OUTPUT
inverted: True
- platform: gpio
pin:
number: 2
mode: OUTPUT
inverted: True
- platform: gpio
pin:
number: 3
mode: OUTPUT
inverted: True
- platform: gpio
pin:
number: 4
mode: OUTPUT
inverted: True
- platform: gpio
pin:
number: 5
mode: OUTPUT
inverted: True
- platform: gpio
pin:
number: 6
mode: OUTPUT
inverted: True
- platform: gpio
pin:
number: 7
mode: OUTPUT
inverted: True
Code Snippet
- if:
- type: is_value
condition: device
device_id: 5041ec09e6b48fe1b1bfbcdbe9e022bd
entity_id: 131d0c6cc0d47944cf65e959685d13ac #Accel Sensor Y
domain: sensor
below: -0.3
- type: is_value
condition: device
entity_id: 97c4ba1bab5b47dc61bd2c0a0cedd9ee #Accel Sensor X
domain: sensor
above: 0.4
below: 0.6
then:
- type: turn_on
device_id: 43d10517571fdae81451a6b8c6dfbf4d
entity_id: bd32cd0cee01422724da049f19892d5e #Relay RF Fill
domain: light
- type: turn_on
entity_id: b5c7db786764111ae2bb905b6c783dcd #Relay LF Fill
domain: light
- wait_for_trigger:
- type: value
platform: device
domain: sensor
above: -0.3
below: -0.1
continue_on_timeout: false
- type: turn_off
domain: light
- type: turn_off
domain: light
