A package for pulsating lights. Useful as a indicator for alarms etc
Could you not store it in an input Boolean ?
And then just read it back out again ?
I might be failing to understand what your trying to achieve tho.
I now use a couple of input_text and _number to store states defined at script start.
But, im struggling to set entity_id from state in a input_text.
Ex
- service: light.turn_on
data_template:
entity_id: {{ states(‘input_text.xxx.’) }}
Any ideas or work around?!
In this case i’m more of an ideas man, rather than an imputation man…
Well i finally came up with a working script for pulsating lights.
I have baked it into a package wich can be found here if someone else wants to use it.
There is also videos with the script in action!
https://binetmedia.se/s/f5Q4Yswza3Bi2Bo
https://binetmedia.se/s/3GzMbgLRQg6ySMg
https://binetmedia.se/s/tE8tFa9PtidTToR
########## Package / Pulselight ##########
########## Author: Daniel Karlsson
########## Date: 10.08.2018
# The script is being called with following data
# "light_id": "light.xxxxx" > the light entity_id you wish to control
# "brightness": "xxx" > max brightness the light should reach
# "transition": "xxx" > the time the light will pulsating
# "delay":"xx" > this value should be equal or more tha transition
# "color":"red" > name of the color the light should being
# In automation the script is called as followed
# action:
# - service: script.pulselight_start
# data:
# brightness: '200'
# color: red
# delay: '05'
# light_id: light.xxxx
# transition: '5'
# There is a input_boolean condition in the script for easy stopping of the loop
########## Customize ##########
homeassistant:
customize:
script.pulselight_loop:
hidden: true
script.pulselight_action:
hidden: true
script.pulselight_start:
hidden: true
input_text.pulselight_color:
hidden: true
input_text.pulselight_light_id:
hidden: true
input_number.pulselight_transition:
hidden: true
input_number.pulselight_delay:
hidden: true
input_number.pulselight_brightness:
hidden: true
########## Entites for Pulselight ##########
input_boolean:
pulselight_active:
initial: off
icon: mdi:blur-radial
input_text:
pulselight_color:
initial: Red
name: Pulselight Light Id
initial: none
input_number:
name: Pulselight Transition
initial: 10
max: 255
min: 0
step: 1
pulselight_delay:
initial: 10
max: 255
min: 0
name: Pulselight Brightness
initial: 250
max: 255
min: 0
########## Script for Pulselight ##########
script:
pulselight_start:
alias: Pulselight Start
sequence:
entity_id: input_boolean.pulselight_active
- service: input_number.set_value
data_template:
entity_id: input_number.pulselight_brightness
value: '{{ brightness }}'
- service: input_text.set_value
data_template:
entity_id: input_text.pulselight_color
value: '{{ color }}'
data_template:
entity_id: input_number.pulselight_transition
value: '{{ transition }}'
data_template:
entity_id: input_number.pulselight_delay
value: '{{ delay }}'
data_template:
entity_id: input_text.pulselight_light_id
value: '{{ light_id }}'
- service: script.turn_on
data_template:
entity_id: script.pulselight_action
pulselight_action:
alias: Pulselight
sequence:
- condition: state
state: 'on'
- service: homeassistant.turn_on
data_template:
brightness: '{{ states.input_number.pulselight_brightness.state | int }}'
color_name: '{{ states.input_text.pulselight_color.state }}'
transition: '{{ states.input_number.pulselight_transition.state | int }}'
entity_id: '{{ states.input_text.pulselight_light_id.state }}'
- delay: 00:00:{{ states('input_number.pulselight_delay') | int }}
- service: homeassistant.turn_off
data_template:
entity_id: script.pulselight_loop
# Looping the scripts
pulselight_loop:
alias: Pulse Loop
sequence:
data_template:
Wow, awesome work.
Thanks… i followed your advice using input_xxx for storing values. Keep it simpel is often best! Ty
