It’s possible via action recorder.purge purge all entities without certain sensors?
You can purge all, action: recorder.purge
Or you can purge a list of entities, action: recorder.purge_entities
There are no other purge actions.
You could construct a template for all entities except those on your exclude list and use that with the purge entities service.
keep_days: 0
entity_id: >
{% set exclude = ['sensor.foo','sensor.bar'] %}
{{ states
| selectattr('entity_id')
| rejectattr('entity_id','in', exclude )
| map(attribute='entity_id')
| join(',')
That will purge everything except sensor.foo
and sensor.bar
Thanks for the solution!
