Purge all info from integration & utility sensor (helper)
I was playing with the configs of integration and utility sensor and now I figured out which one is best for my scenario.
But now I can’t delete the history of all those entity.
I tried in Developer > Service > recorder.purge_entities and it did not work.
Then I tried using some sql lite commands and did not work either.
So I decided to go extreme and then I deleted the DB.
But after I created one sensor with the same name as before it still shows history sum as below.
So, how can I delete that? And if I perform some test again how can I delete all history of a helper?
Use the utility_meter.calibrate service in Developer Tools → Services to set the value to 0.
That worked. Tks
