Purge is incorrectly removing historical data
Background
I have some scripts Schedule to purge data using different days on configuration depending of the time I want to keep the data.
This purge scripts are scheduled weekly.
I expected this to remove old data on the DB
Problem
I realize my DB keep growing so I realize I was just doing a purge, but never a repack to actually “shrink” the dab.
I create a new script to “force” a REPACK:
  - action: recorder.purge
    metadata: {}
      repack: true
I executed and after some hour my DB decrease a lot, (from around 15000Mb to 5000Mb)
I do a quick check, and all looks ok. So I was so happy.
Then I realize I have lost all my old data: basically my older data is now for Aug. 16th (around 10 days ago), but I would like to keep some entity info for a year):
before repack
After repack
I restore the back up and data is back.
Just to be sure I did same procedure and check my data on every step and I am 100% sure data is removed by repack action, and not on any other purge action.
What I am missing there? I understand repack should ONLY shrink BD to take advantage of free space on the DB, but should never remove data, correct?
Any idea?
NOTE: I am also using influx DB ad Grafana for old data storage and consult, but I need to fully understand why purge is removing data when should not.
NOTE_2: I also create an issue on github, as per my understanding repack would never remove data, but let m ekno if make sense to only keep this.
thansk
Hi, anyone can help, at least to confirm if repack should remove data or not? Anything you see wrong on the script?
thanks
State data is kept foe 10 days (by default) then deleted automatically. Everything you have observed is working as intended.
Thanks! So I should add a bigger number of days to do the repack without loosing data, correct?
Do not set your keep days longer than 30 days or you may see reduced performance.
This will increase the size of your database by a factor of 3.
What are you actually trying to accomplish?
The database is repacked every month automatically. Why are you manually doing this?
Hi
i am tring to keep one year for some temp and power consume entities to be able to compare, not fro all entities…
I did not see any performance issue so far, and some entities are already restored for more than a year. As I told, for other entities, I used to purge data older than a week or a month… (i have my own purge scripts running every week.)
No, repack is not running automatically as I have auto-purge option disabled, this is why i what to manually run.
I will reconsider my purge retention policies one more time, but i do nto feel keeping old data just for a few entities should harm the system (i am using arround than 20% of my HD. less than 30% of RAM and 5% of CPu as avg)
Then give these sensors a state class and LTS will be kept forever. Do not set your recorder to retain more than 30 days.
Repack happens automatically first Sunday of the month.
second
Dammit I initially wrote:
Repack happens automatically first (second?) Sunday of the month.
But deleted that bit.
Heh, I don’t know why it’s the second sunday :man_shrugging:
