Trying to figure out how to add this widget to HOME ASSISTANT. Adding “webpage” card doesn’t do it.
code to do it:
<div id='PurpleAirWidget_60025_module_AQI_conversion_C0_average_0_layer_standard'>Loading PurpleAir Widget...</div>
<script src='https://www.purpleair.com/pa.widget.js?key=CIMBJ1DAL7LA5HMT&module=AQI&conversion=C0&average=0&layer=standard&container=PurpleAirWidget_60025_module_AQI_conversion_C0_average_0_layer_standard'></script>
GlennHA
(Glenn)
January 7, 2021, 8:45pm
2
Did you ever get what you wanted?
I was just searching for other PurpleAir stuff and came across your post.
If you don’t there is another tread that has all the info you need.
Not the widget, but I did get the sensors integrated.
Sheesh, we’re all doing the same things. Life in CA I guess? So I have a pms5300 on an esphome and it works great. I get the raw values In the log but am struggling with how to get to the AQI conversion. My esphome has a sensor as follows:
- platform: pmsx003
type: PMSX003
pm_1_0:
filters:
#- throttle: 60s
- delta: 2.0
- sliding_window_moving_average:
window_size: 45
#name: "Particulate Matter <…
And built my own purple air sensor for $15 as well. I’m “George Jetson” in this thread
https://blog.brendon.net/diy-purpleair-sensor/#comment-5119863481
