Purpleair Widget - CSS code in lovelace
Trying to figure out how to add this widget to HOME ASSISTANT. Adding “webpage” card doesn’t do it.
code to do it:
<div id='PurpleAirWidget_60025_module_AQI_conversion_C0_average_0_layer_standard'>Loading PurpleAir Widget...</div>
<script src='https://www.purpleair.com/pa.widget.js?key=CIMBJ1DAL7LA5HMT&module=AQI&conversion=C0&average=0&layer=standard&container=PurpleAirWidget_60025_module_AQI_conversion_C0_average_0_layer_standard'></script>
Did you ever get what you wanted?
I was just searching for other PurpleAir stuff and came across your post.
If you don’t there is another tread that has all the info you need.
Not the widget, but I did get the sensors integrated.
And built my own purple air sensor for $15 as well. I’m “George Jetson” in this thread
https://blog.brendon.net/diy-purpleair-sensor/#comment-5119863481
