Got the same issue, seems to work only when the app gets set up for the first time. After an app restart (doesnāt need to be force closed) notifications will stop working. Strangely on my wifes phone (same conditions, HA 0.92.2 and iOS 2.0 build 44) notifications seem to work fine. On both phones the integration was removed as well as reinstalled the app.
I had no notification target too after deleting from known_devices, mobile_app, removing the integration and upgrading my Companion app to 44.
Hereās how I resolved it. I donāt know how reproducible it is but I fiddled for quite a while before trying this so I think itās not a coincidence. By going to iOS settings -> Privacy and completely disabling Location Services, then re-enabling it, it looks like all interested Apps request an update. After that my notification target was available.
Unfortunately the problem persists with the latest build. When reinstalling the app with build 40 (and removing the mobile_app integrations first) notifications seem to work again. Seems to work until build 40, when installing 42, the sensors will be recreated and the problems start there).
Though what is really crazy is that my ipad air and my wifes iphone xs has no problems at all. Notifications work fine for those two devices. My iphone x however is the only device with these problems.
I have come to think about this and I recently updated my iphone X (been running ios betas for the last 5 years) maybe someone could confirm that they have this problem on a release build of ios 12?
Anyways great work Robbie, Great work, we will all patiently wait and the ones that donāt have the patience should leave HA
Someone here knows what this error indicates? Push notifications does not Work with beta 46 only with 1.5.1 (3) on the same device.
[homeassistant.components.homeassistant] Invalid config for [automation]: Service notify.mobile_app_jespers-iphone does not match format . for dictionary value @ data[āactionā][2][āserviceā]. Got None. (See /home/homeassistant/.homeassistant/configuration.yaml, line 18)
solved it. It must have been a typo when getting the device name from dev tools.
Device name of my iphone was ājespers-iphoneā but in dev tools now it says ājespers_iphoneā
Now I guess I have the same issue as in the other posts here. Notifications only worked the first time after setting it up.
Can you post your worming automation? Iām still fighting with mine but itās probably in need of some reboots. I donāt get a notify service in the services list besides notify.notify, unless thereās a way to use that and no andevice specific notify service call. You working automation example would be a big help. Thanks!
Setup the app (the onboarding part) refresh the page by pulling down (after logging in) restart HA and you should have notify.mobile_app_NAMEHERE appear in the list. But it probably wonāt work as there is a bug which is currently being worked on.
Hey Rob thank you for all your hard work on this app. I just updated to build 52 and for some reason the app kept on crashing. Iām on ios 12.2 iphone 8 plus.
