@dshokouhi Think it would be possible to get ‘image’ changed to ‘image_url’ or added as a alias to ‘image’ to match the other notification services?
There is actually some discussion about that right now. The goal of this is to simplify the mobile_app
platform rather than notify
as a whole. However if there is a standard being used we should use that. What other platforms use image_url
? When I look at discord it uses file
which is under path
, hangouts uses image_file
everyone seems to have their own schema.
image_file
is for sending the image using the local path. It also uses image_url
for sending image urls ie: https://<your HA instance>/local/yourimagefile.gif
Found the service call for it here:
Might need some kind of standardization in the whole notifications component section
Yup we do lol Make notification services more consistent · Issue #329 · home-assistant/architecture · GitHub
Is it possible to have animated gifs animated? I tried sending a gif and it just shows the first frame.
Is there a way to open the link after clicking on the notification message? For example, go to the release notes page from an update message…
Yes use clickAction
https://companion.home-assistant.io/docs/notifications/notifications-basic/#notification-click-action
Great! Thanks for the quick reply
I want to send a camera snapshot in the notification but I can only see part of the photo. how to fix it?
System - Android
Orginal
Already answered it
Do a resize first with a script and send that modified image ;(
could you help me how can i get a resized notification? What I have to do? do you have any example I would really be grateful
No, no example… But I think if you Google for a python script to resize am image, you will find enough
i cant get a picture to send for toffee!!!
i’ve tried all the following but nothing, just the text
title: "Doorbell"
message: "Someone is at the front door"
image: /local/config/www/my_image_back.jpg
title: "Doorbell"
image: https://my_code.ui.nabu.casa/api/hassio_ingress/some random key/api/file?filename=/config/www/my_image_front.jpg
title: "Doorbell"
image: https://my_code.ui.nabu.casa/config/www/my_image_front.jpg
but nothing seems to work i’m just calling notify.mobile_app_sm_g965f from the services tab at the moment
this is wrong the path shouldn’t contain /config/ use: https://my_code.ui.nabu.casa/local/my_image_front.jpg
Mate your a star, pic is sending fine now.
edit: ignore comment i just need to slide it down to show full image!!!
I’m curious what happens to notifications if the intended mobile app is inaccessible (i.e. powered off or not connected to the internet). Are notifications lost or are they queued for when phone is back online?
There is a setting in the message for how long they should be queued so I suppose they are queued
There is part of it here: FCM संदेशों के बारे में | Firebase Cloud Messaging Just keep in mind that setting ttl
to anything but 0
means the message will not be sent to the device immediately. But setting it to 0
means if it can’t be delivered it gets discarded.
