Push or request state to InfluxDB
I have a temperature sensor that will update influxdb and the graph it in Grafana that works normally.
The problem occurs when I restart home assistant, if the sensor hasn’t changed temperature then the graph in Grafana drops to a very low temperature which is incorrect and not the same as the state that’s showing in the temperature gauge in Lovelace.
As soon as a new state(temperature) is update the graph will pick up the correct state.
I suppose I,m looking for a ‘push’ state to influxdb or a request from influxdb after home assistants starts, is there such a thing or a work around.
im using the influxdb and Grafana add ons al latest releases all round.
