Hello Community,
i try to push my temperature and humidity values to PRTG. There is also a nice video about exactly this use case here and the github page here
I created a automation for each nodemcu that will push the data to prtg every 2 minutes…then i realized the issue…every time the automation runs, the one value is correct but the others are zero…which doesn’t look good in the graphs.
- id: '159999999999'
alias: PRTG Temperature Bath
description: ''
- minutes: /2
platform: time_pattern
condition: []
- data_template:
sensor_name: Bath Temperature
value: '{{ states.sensor.bath_temp.state | int }}'
service: rest_command.prtg
mode: single
Then i noticed at the PRTG sensor description this:
If you use this sensor with multiple channels, we recommend that you simultaneously push the data for all your channels to PRTG. You can push data to only one of your channels but, in this case, all other channels record the value of 0 for this push message.
So the question is, how can i send all sensor values at once? i tried to add another sensor_name and value in the data_template but that doesn’t work.
I watched some videos and search around but i can’t figure out how to do this!? Maybe someone has an idea
