Push Token
I’ve noticed that the app displays the push token that is used for notification confiuration in HA. However, this same value is referred to as a pushId in ios.conf with the actual Apple push token having the key pushToken. This may lead to confusion.
I think the app should refer to the value as Push ID for consistency with ios.conf.
Good call, will fix, thanks!
