Hello to everyone,
did someone could help me to create a virtual push button that when pressed, for example return a start command via lambda? this is the code:
Arduino Program:
ESPHome:
Best Regards
Stefano
Hello to everyone,
Arduino Program:
ESPHome:
Best Regards
Stefano
You could use a template button and the on_press
to trigger a lambda action.
button:
on_press:
then:
- lambda: |-
id(some_binary_sensor).publish_state(false);
Thanks a lot @Mikefila for your reply
sorry but i don’t understand how to pass the start command for example.
I can punt this in the yaml:
button:
on_press:
then:
- lambda: |-
here i need to pass command start or stop or dock etc;
This is the code that must be executed when i press the button:
void on_command(std::string command) {
this->brc_wakeup();
if (command == "turn_on" || command == "turn_off" || command == "start" || command == "stop")
this->roomba.cover();
else if (command == "dock" || command == "return_to_base")
this->roomba.dock();
else if (command == "locate")
this->roomba.playSong(1);
else if (command == "spot" || command == "clean_spot")
this->roomba.spot();
else if (command == "wakeup" || command == "brc_wakeup")
this->brc_wakeup();
So i need to simulate the on_command with the virtual button.
Thanks again a lot
Best Regards
Stefano
