Pushover and priority
Hi All,
I have some notifications send by Pushover. I see that notifications with
priority: 2
Gives a error. When i change this to 0 or 1 then the notification is send normal.
On the site it Pushover you can use different priorities include the 2:
https://pushover.net/api#priority
Here the error log:
2020-11-04 13:34:06 ERROR (MainThread) [homeassistant.components.automation.notification_update_available_notification] Notification - Update Available Notification: Error executing script. Unexpected error for call_service at pos 1: 400: retry is invalid
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 253, in _async_step
    await getattr(
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 463, in _async_call_service_step
    await self._async_run_long_action(service_task)
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 422, in _async_run_long_action
    long_task.result()
  File "/usr/src/homeassistant/homeassistant/core.py", line 1448, in async_call
    task.result()
  File "/usr/src/homeassistant/homeassistant/core.py", line 1483, in _execute_service
    await handler.job.target(service_call)
  File "/usr/src/homeassistant/homeassistant/components/script/__init__.py", line 215, in service_handler
    await script_entity.async_turn_on(
  File "/usr/src/homeassistant/homeassistant/components/script/__init__.py", line 320, in async_turn_on
    await coro
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 1010, in async_run
    await asyncio.shield(run.async_run())
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 710, in async_run
    await super().async_run()
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 245, in async_run
    await self._async_step(log_exceptions=False)
    await getattr(
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 460, in _async_call_service_step
    await service_task
    task.result()
  File "/usr/src/homeassistant/homeassistant/components/notify/__init__.py", line 147, in _async_notify_message_service
    await self.async_send_message(**kwargs)
  File "/usr/src/homeassistant/homeassistant/components/notify/__init__.py", line 126, in async_send_message
    await self.hass.async_add_executor_job(partial(self.send_message, message, **kwargs))  # type: ignore
  File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
  File "/usr/src/homeassistant/homeassistant/components/pushover/notify.py", line 97, in send_message
    self.pushover.send_message(
  File "/usr/local/lib/python3.8/site-packages/pushover_complete/pushover_api.py", line 198, in send_message
    return self._send_message(user, message, device, title, url, url_title, image, priority, retry, expire,
  File "/usr/local/lib/python3.8/site-packages/pushover_complete/pushover_api.py", line 160, in _send_message
    return self._generic_post('messages.json', payload=payload, session=session)
  File "/usr/local/lib/python3.8/site-packages/pushover_complete/pushover_api.py", line 88, in _generic_post
    raise BadAPIRequestError('{}: {}'.format(resp.status_code, ': '.join(resp_body.get('errors'))))
pushover_complete.error.BadAPIRequestError: 400: retry is invalid
Changes something in script and now it work again:
priority == '2'
to
priority == 2`
pushover_engine:
  alias: "Notify Pushsover Engine"
  description: "Pushover Engine to send messages to my mobile phone"
  mode: queued
  sequence:
    - service: notify.pushover
        message: "{{ message }}"
        title: "{{ title }}"
          priority: "{{ priority }}"
          sound: >-
            {% if priority == 2 %} {{ sound }}
            {% else %} pushover
            {% endif %}
          retry: >-
            {% if priority == 2 %} 60
            {% else %} 0
            {% endif %}
          expire: >-
            {% if priority == 2 %} 3600
            {% else %} 0
            {% endif %}
