I’m trying to send some push notifications to my phone, so I’ve added the following configuration to use Pushover for that:
notify:
- platform: pushover
api_key: [my API key]
user_key: [my user key]
When I restart Home Assistant I get the following error:
17-03-17 14:26:29 ERROR (MainThread) [homeassistant.setup] Not initializing notify.pushover because could not install dependency python-pushover==0.2
17-03-17 14:26:29 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform notify.pushover: Could not install all requirements.
17-03-17 14:26:29 ERROR (MainThread) [homeassistant.components.notify] Unknown notification service specified
I had the same issue with Pushbullet before. That was the reason for me to switch to Pushover.
I’ve been running the All-in-one, so not sure how Hassbian handles installs. I wonder if you need to manually install pip to get dependencies. Have you tried manually installing python-pushover?
Thank you for your answer but apt tells me that this package doesn’t exist.
However - today I restarted Home Assistant again and got a little bit more information in the log file:
17-03-18 16:56:05 ERROR (MainThread) [homeassistant.components.notify] Error setting up platform pushover
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/notify/__init__.py", line 101, in async_setup_platform
None, platform.get_service, hass, p_config, discovery_info)
File "/usr/lib/python3.4/asyncio/futures.py", line 388, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.4/asyncio/tasks.py", line 286, in _wakeup
value = future.result()
File "/usr/lib/python3.4/asyncio/futures.py", line 277, in result
raise self._exception
File "/usr/lib/python3.4/concurrent/futures/thread.py", line 54, in run
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/notify/pushover.py", line 32, in get_service
from pushover import InitError
ImportError: No module named 'pushover'
I installed python-pushover with
sudo pip3 install python-pushover
It told me that the installation was successful but I still get the error.
