conradh
(Conrad Hagemans)
1
Today I upgraded to latest 2022.9 version. I got a warning that Pushover is no longer configured via YAML but as integration.
But Pushover is not migrated?? I cannot see it under integrations. And if I want to add is as new integration it fails.
Errors in log file that messages cannot be send.
So I guess somewhere in an hidden setup file there is some leftover over the migration that failed.
Where are the settings stored?
Anybody else the same problems?
There was a multi-target bug that was fixed in x.9.2 I believe.
conradh
(Conrad Hagemans)
3
Thank you.
I updated to 2022.9.4.
Still not able to add pushover as new integration.
Did you by any chance have multiple pushover accounts setup?
conradh
(Conrad Hagemans)
5
No. I am using one pushover account.
Is it possible that there are some settings left on the server.
Can I manually remove them?
If you haven’t already, I would remove everything related to Pushover, and then re-install after a reboot.
conradh
(Conrad Hagemans)
7
I cannot. The integration doesn’t show up. And I cannot reinstall it. So I am stuck without Pushover.
