I am using HASS for some time now and I am still amazed by the speed and quality of development ! Cheers to all that make this possible.
My automation setup uses pushover and although the implementation is working according to the documentation on the HASS website one feature is missing : HTML formatting
Since v0.3 the same library HASS uses allows the use of HTML formatting of the message. Ive just copied the v0.3 sourcecode from the developer of python_pushover to the /srv/hass libraries.
It works as planned, all old functionality is there and the new html formatting also works.
But … it would be nice if the default library that HASS installs for pushover now can become 0.3 instead of the 0.2. I have no idea where to ask this ? Its not really a feature request I think.
My test was very simple, I have a running HASS setup that uses many options of pushover:
sound
priority
verify
expire
When I copied the 0.3 pushover onto the version in /srv/hass (whilst first making an old copy) things are still working as planned (tested). I now also use calls with html as a keyword.
I run most of my stuff from Appdaemon scripts, made a function I can call easy:
title and message are the defaults and data can contain additional json keywords.
self.call_service(“notify/pushover”, title=title1, message=message1, data=data1 )
Are you getting priority to work? I can’t seem to do it from my script. The code below works as is, but not if I add the priority=2-attribute. I’m running 0.55.
Pushover in hass is a little strange. To get priority to work you need to add another data section for metadata to your data template. The config below should work.
If you would like to use priority 2 you will need to provide some additional data which can be found in the pushover api doc’s. https://pushover.net/api#priority
