I would like to put in a text file the latest temperature read from a sensor (aeontec here), how can i acheive that ?
Michael
Michael
My guess from googling txt file and HA shell command instructions. (the quotes might be wrong, perhaps outside ones are double)
shell_command:
temp2txt: 'echo '{{ states.input_number.ac_temperature.state }}' >foo.txt'
Thank you Roby, but how to update that file each time the temperature is changing ?
Michael
an automation that is triggered on the state change of the sensor and the action is the shell command.
almost exactly like the documentation example
automation:
- alias: run_set_ac
platform: state
entity_id: input_number.ac_temperature
service: shell_command.set_ac_to_slider
What is the synthax exactly to retreive the data sensor ? i have try many thing whithout making it works
In the developper tools menu, the name of my sensor is :
sensor.aeotec_zw100_multisensor_6_temperature
i have tried
shell_command:
put_temp_in_file: echo '{{ states.sensor.aeotec_zw100_multisensor_6_temperature.state }}’ > foo.txt
put_temp_in_file: echo '{{ (states.sensor.aeotec_zw100_multisensor_6_temperature.state) }}’ > foo.txt
put_temp_in_file: “echo '{{ states.sensor.aeotec_zw100_multisensor_6_temperature.state }}’ > foo.txt”
This has worked
put_temp_in_file: echo ‘hello’ > /tmp/temperature.txt
So the issue is the way i’m calling the sensor data.
Thx
Hi
I’m experiencing the same.
Have you found a way to do it?
Does this help here
