fastender
(Fastender)
1
Unfortunately involuntarily I had to switch to hass.io.
Also my configuration synonymous transferred, SSH I have also set (WinSCP did not work, have switched to CyberDuck).
Now my problem:
About Putty I can not type commands? Where is the problem.
pvizeli
(Pvizeli)
2
It does not work while you run inside a sandbox. So if you want install Software you Need write a addon for it.
fastender
(Fastender)
3
But the Timezone is false, how can i edit it?
pvizeli
(Pvizeli)
4
In forum topic releasenote should be stay a command to set it nanual
