I have Daikin integration which is based on a climate controller. The Daikin integration is a bit limited, and only two preset modes are supported, ‘none’ and ‘away’. But it is still possible to change the preset mode from the GUI (lovelace card). If you change preset to ‘eco’ for instance, this is clearly stated on the card.
I want to use this indicator and just change the temperature setting in an automation and at the same time change the indication of the preset mode. I tried to change the indicator (preset mode) by an action like this:
- service: climate.set_preset_mode
entity_id: climate.gamla-huset
preset_mode: eco
this gives me the following error:
Invalid config for [automation]: not a valid value for dictionary value @ data['action'][1]['target']['entity_id']. Got None. (See /config/configuration.yaml, line 4
I struggled quite some time with this without success, but finally found an example based on data_template instead of data. I changed the action like this:
data_template:
entity_id: climate.gamla_huset
preset_mode: eco
and everything works fine!
I have learned data_template is deprecated and should not be used any more, so this puzzles me a lot.
What’s the problem with my first variant?
