Has anyone any clues on how I diagnose the following error? The script appears valid in both the visual editor and YAML and I’ve checked that the correct devices/entities are referenced, and reselected the radio station requested from the HA Radio Browser. The script only seems to run as far as the initial attempt to set the volume.
Thanks.
alias: Radio 4 on soundbar (script)
description: Play on soundbar at 28% volume
sequence:
- service: media_player.volume_set
volume_level: 0.28
area_id: living_room
entity_id: media_player.soundbar_2
- service: media_player.play_media
entity_id: media_player.googlehome4201
media_content_id: ""
media_content_type: ""
metadata: {}
media_content_id: media-source://radio_browser/d470fda1-753b-4037-973f-6f1bd27eb42f
media_content_type: audio/aac
metadata:
title: BBC Radio 4
thumbnail: https://i.imgur.com/OCqneDN.png
media_class: music
children_media_class: null
navigateIds:
- media_content_type: app
- media_content_type: music
media_content_id: media-source://radio_browser/country/GB
mode: single
icon: mdi:audio-video
Trace reads:
Play media on Corner
(script.1708445821467) turned off
Stopped because an error was encountered at 21 February 2024 at 12:05:14 (runtime: 0.06 seconds)
string index out of range
Either remove that service call or supply it with some content to play.
If that fails to fix the error, post the automation’s entire trace file (click Traces, then click the overflow menu, that’s the three vertical dots, then select Download Trace).
Thanks for your input, Taras. I should have noticed my scripting error - but I definitely remember adding the content to play, so HA must have removed it. It seems that, even with the visual editor, writing a script that works is far from simple, as I’ve now added text to speech there (which plays) again and on the next run got an error at the end of the script. Although I have only one physical device called Soundbar, HA for some reason thinks I have two and I was only able to clear the error by selecting the one with the speaker icon that initially had a diagonal line through it, suggesting it was disabled…
In your previous post (the one you deleted) you had posted the trace file. I could see that the error message was definitely due to what I described in my first post, namely it’s the media_player.play_media service call with no content (i.e. empty media_content_id and media_content_type).
The solution is what I had suggested, either remove the service call or supply it with content.
I can’t comment on how or why there’s no content, just the fact that its absence is the source of the error message.
I would need to see the trace file for that run.
Do media_player.soundbar and media_player.soundbar_2 use the same integration? Which one?
Are they part of the same device (in the Devices list) or separate ones?
Thanks for replying again. I now have the script working but haven’t got to the bottom of the issue with the two devices. One shows as Google Cast and the other as DNLA Media Renderer, and I’m still unclear on which one works because neither of the icons that appear in the devices list is the (working) speaker one that I saw in the scripts visual editor.
