Puzzling swipe behaviour: using slider buttons, navigation to different view panel occurs
I am noticing undesired behaviour, using HA iOS app.
In a dashoard, with multiple views, I have installed buttons, which have sliding functionality. (type:light with horseshoe slider and custom:slider-button-card). I notice this behaviour, using either button.
Behavoiur:
when using the slide function, the action controls light brightness as intendend. When “releasing” the button, the change to a different view occurs. Apparently, the direction of navigation is consistent with the direction of the slide action.
So for some reason, the use of the slider is also interpreted as a swipe navigation command.
I am not aware of having installed or specified swipe navigation; I also don’t know, where to verify, if I have, or where to switch it off, if installed.
I am also not aware, of any iOS specific feature, which can be controlled through the mobile device (app) directly
The behaviour is definitely undesired and makes the dashboard virtually unusable on the device, as I constantly have to navigate back to the original view.
Any input how to adjust or remove this behaviour?
Problem solved
