PV Excess Optimizer and Huawei Inverter - which Sensors to use?
Hi all,
I want to use PV Exccess Optimizer together with an Huawei Inverter. But I dont know which Sensors to use for “Export Power”, “Load Power” and “Combined Import / Export Power”. I also don’t get the realtionships between them.
  • The blueprint states for “Export Power” : current export power to the grid in watts. But I have only an export sensor im Kwh. It also states that this sensor needs to be provided together with the “Load Power” sensor
  • The blueprint states for “Load power sensor” : combined household appliance consumption without home battery charging consumption. Here I have to possible sensors, which I can’t distinguish, maybe because the inverter is adjusted to zero feeding to the grid. These are “Active Power” and “Input Power”. Maybe I’m wrong here.
  • The blueprint states for “Combined Import/Export Power” : Do not use this sensor when you have a hybrid inverter with battery. Otherwise the script cannot detect when your battery is discharging to compensate for a load!
But I have a battery.
What to do now? Is there someone who has experince with this?
Clueless, muellthos
Hi muellthos,
did you solve your problem in the meantime?
I have the exact same issue.
I have let it go
