Hi all,
i try to use PV Excess to switch on my dishwasher with this yaml:
input_boolean:
spuelmaschine_automatisierung:
name: Spülmaschine Automatisierung
initial: off
- id: spuelmaschine_steuern
alias: Spülmaschine steuern
- platform: numeric_state
entity_id: sensor.werkstatt_power_consumption
above: 100
- type: turn_on
device_id: 5d963ce5fb6a31688b770fe5d71f
entity_id: switch.shellyplug_e31
domain: switch
mode: single
I measure with sensor.werkstatt_power_consumption the output from PV. The automation works, when the sensor.werkstatt_power_consumption is under 100 W and raise then to over 100 W.
But its NOT working when the sensor.werkstatt_power_consumption is already over 100 W and i trigger spuelmaschine_automatisierung to on.
Where do i do the mistake?
Appreciate all help and hints
Thank you!
