Hi I am a new oldie, having fun with HA,& Node-red but I am a bit stuck
I am using a QNAP Docker version home-assistant:2022.2.0.dev20220101
The PVoutput integration is showing in the list and I can enter the information and it reports success.
However there is no entity and this is the log relating to it.
In my first attempt at HA i used a much earlier version and added the PVoutput in the config file which worked. Can anybody help me?
[u]LOG FILE[/u]
Logger: homeassistant.components.sensor
Source: components/pvoutput/sensor.py:165
Integration: Sensor (documentation, issues)
First occurred: 11:19:18 (5 occurrences)
Last logged: 13:10:40
Error while setting up pvoutput platform for sensor
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 249, in _async_setup_platform
await asyncio.shield(task)
File "/usr/src/homeassistant/homeassistant/components/pvoutput/sensor.py", line 165, in async_setup_entry
system = await coordinator.pvoutput.system()
File "/usr/local/lib/python3.9/site-packages/pvo/pvoutput.py", line 137, in system
return System.parse_obj(
File "/usr/local/lib/python3.9/site-packages/pydantic/main.py", line 511, in parse_obj
return cls(**obj)
File "/usr/local/lib/python3.9/site-packages/pydantic/main.py", line 331, in __init__
raise validation_error
pydantic.error_wrappers.ValidationError: 1 validation error for System
zipcode
value is not a valid integer (type=type_error.integer)
