PVOutput - sensors not updating
I am still not comfortable in configuration.yaml, is there something more I have to do in order to make this work?
That’s my sensor config for PVOutput.
sensors:
      power_consumption:
        value_template: "{% if is_state_attr('sensor.pvoutput', 'power_consumption', 'NaN') %}0{% else %}{{ state_attr('sensor.pvoutput', 'power_consumption') }}{% endif %}"
        friendly_name: "Using"
        unit_of_measurement: "Watt"
      energy_consumption:
        value_template: '{{ "%0.1f"|format(state_attr("sensor.pvoutput", "energy_consumption")|float/1000) }}'
        friendly_name: "Used"
        unit_of_measurement: "kWh"
      power_generation:
        value_template: '{% if is_state_attr("sensor.pvoutput", "power_generation", "NaN") %}0{% else %}{{ state_attr("sensor.pvoutput", "power_generation") }}{% endif %}'
        friendly_name: "Generating"
      energy_generation:
        value_template: '{% if is_state_attr("sensor.pvoutput", "energy_generation", "NaN") %}0{% else %}{{ "%0.2f"|format(state_attr("sensor.pvoutput", "energy_generation")|float/1000) }}{% endif %}'
        friendly_name: "Generated"
You need a customize.yaml file if you want the energy tab to pick up PVOutput sensors.
sensor.powerpal_output_total:
  state_class: total_increasing
sensor.powerpal_output_actual:
  state_class: measurement
To use a customize.yaml file you need to add the customize line to your config.yaml. (packages is unnecessary, although useful for making a PVOutput_Sensors.yaml etc)
homeassistant:
    packages: !include_dir_named packages
    customize: !include customize.yaml
Worth checking your logs too to occasionally you can cap out the hour limit on requests.
I’m having a hard time making this work, the sensors are not being created. I have created the customize.yaml, this is my configuration.yaml:
    system_id: xxxx
    api_key: xxx
    sensors:
      power_generation:
      energy_generation:
        unit_of_measurement: "kWh" ```
Hmm that is my whole pvoutput_sensor.yaml. its in a separate package file. That shouldn’t matter if you are under the sensor spot in config.yaml. My dev tools output is below. You have restarted HA? any errors in the logs?
  - platform: pvoutput
    system_id: YOUR_SYS_ID
    api_key: YOUR_PVO_API_KEY
    sensors:
      power_consumption:
      energy_consumption:
      power_generation:
      energy_generation:
Thanks, I had to clean my configuration-file, it was messy due to my lack of understandig how it works.
I’ve got it working now, thanks a lot!
