PVOutput suddenly stopped
I have been using the PVOutput platform for quite som time without issue. For whatever reason is suddenly stopped working. I installed an App “PV Display” on my mobile phone and I though that I might be over the maximum number of request.
I checked the status with
 http://pvoutput.org/service/r2/getstatus.jsp?key=xxxx&sid=zzzz
This give me however a normal reply
20201114,15:10,1219,228,NaN,NaN,0.069,32.2,236.4
I upgraded to the latest HassOS 4.16 to make sure that that was not the issue
I also tested the REST component
- platform: rest
  resource: http://pvoutput.org/service/r2/getstatus.jsp?key=xxx&sid=zzzz
  name: Current power generated
  value_template: '{% set list = value.split( "," ) %} {{ "{0:,}".format(float(list[3])) }}'
  unit_of_measurement: Watt
- platform: pvoutput
  system_id: zzzz
  api_key: xxxxx
  scan_interval: 200
I keep getting the folowing error
2020-11-16 09:50:43 ERROR (MainThread) [homeassistant.components.rest.data] Error fetching data: http://pvoutput.org/service/r2/getstatus.jsp?key=xxxx&sid=zzz failed with [Errno -2] Name does not resolve
What is going wrong here ?
